Samsung's sleek Memory Card Camcorder features a powerful 42x Intelli-zoom lens and a 8th generation DSP chip, which basically delivers a whole new level of image brilliance. You can also easily share your memories on the internet and portable devices with the Web and Mobile mode. Add to this the longer battery life, and you have a camcorder that is ready to go exploring.
More recording time, more memories to treasure
Enjoy recording more of the highest quality video footage with the SAMSUNG F30/33/34. Thanks to the high performing H.264 Codec, the F30/33/34 record more of your memories than camcorders which use MPEG2. With the same capacity, the F30/33/34 record about twice more than MPEG2 codec. Its compressed video files are faster to e-mail and upload to the web, which makes sharing as easy as can be, with no loss of Image quality. -
Face detection AF technology
Unlike conventional camcorders, the F30/33/34's advanced Face Detection AF technology targets the faces in the screen. With intelligent face detection auto-focus, faces are always focused-on, even if they are not in the centre of the screen. SAMSUNG's Face Detection AF enables you to capture clearer, higher quality video. -
Colour as vivid as your memories
Digital Natural Colour Processing creates an expanded palette of colours that are closer to those seen in nature. By internally adjusting images beyond RGB into 4 colour CMYG spectral colour matching, the F30/33/34 are able to accurately recreate colours that are closer to those your eyes see, closer to your memories, and closer to reality. -
3D noise reduction
The F30/33/34 transcend the boundaries of convention by introducing 3D noise reduction that dramatically eliminates noise while maintaining the original edge and pattern of the image. By analysing motion between the frames, the frames are split into pattern / edge frames and differential frames and are passed through separate filters which maintain the pattern and edge and remove noise. After filtering, the frames are combined once more to make a cleaner, clearer image. -
The 8th generation DSP chip from SAMSUNG
Experience the most naturally beautiful images with the 8th generation DSP chip from SAMSUNG. Advanced Colour Expression, Hyper Digital Image Stabiliser, Super LCD plus, and Face Detection Auto Focus combine to make your digital image dreams a reality. Longer battery life, extended recording time, and higher quality digital imaging are enabled by the SAMSUNG chip. By designing and implementing a powerful single chip control system, power consumption is dramatically reduced, allowing you to capture more memories that can be treasured for the rest of your life.
- Samsung SMX-F30 - camcorder - Schneider - storage: flash card
- Product Type
- Camcorder
- Lens Included
- Schneider
- Media Type
- Flash card
- Memory Card Slot
- SD card
- Sensor Resolution
- 800 KP
- Effective Sensor Resolution
- Video: 540 KP - Photo: 0.48 MP
- Lens System
- Zoom lens - 34x zoom - 2.3 - 78.2 mm - f/1.6-4.3
- Focus Adjustment
- Automatic, manual
- Digital Zoom
- 1200x
- Image Stabiliser
- Electronic
- Display
- LCD display - 2.7"
- Supported Battery
- Li-ion rechargeable battery - 850 mAh (included)
- Interface
- Composite video/audio, USB 2.0
- Silver
- 6 cm x 12.5 cm x 6 cm
- 270 g
- Product Type
- Camcorder
- Lens Included
- Schneider
- Enclosure Colour
- Silver
- Camcorder Type
- Consumer
- Camcorder Sensor Resolution
- 800 KP
- Sensor Qty
- 1 CCD
- Effective Video Resolution
- 540 KP
- Effective Photo Resolution
- 0.48 MP
- Widescreen Video Capture
- Camcorder Media Type
- Flash card
- Optical Sensor Type
- CCD
- Optical Sensor Size
- 1/6"
- Optical Zoom
- 34x
- Digital Zoom
- 1200x
- Image Stabiliser
- Electronic
- Face Detection
- Services and Applications
- YouTube capture mode
- Digital Video Format
- H.264
- Image Recording Format
- JPEG
- Interface
Exposure & White Balance
- Min Illumination
- 3 lux
- Exposure Modes
- Programme, automatic
- Shooting Programs
- Spotlight, portrait mode, hi-speed shutter, flowing water, food, sports mode, beach, snow
- Special Effects
- Negative, Art, Black & White, Sepia, Mosaic, Pastel, Mirror, Emboss, Stepprinting, cosmetic
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Fluorescent, cloudy, tungsten light, daylight
- Max Shutter Speed
- 1/10000 sec
- Min Shutter Speed
- 1/60 sec
Lens System
- Schneider zoom lens - 34x zoom - 2.3 - 78.2 mm - f/1.6-4.3
- Focus Adjustment
- Automatic, manual
- Zoom Adjustment
- Motorised drive
- Filter Size
- 30 mm
- Built-in lens shield
Additional Features
- Additional Features
- Built-in speaker, Backlight Compensation (BLC), auto power save, digital noise reduction, interval shooting mode
Display
- 2.7" LCD display
- Display Format
- 112,000 pixels
- Display Form Factor
- Rotating
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Microphone Features
- Wind noise reduction
- Connector Type
- USB , Composite video/audio output , DC power input
Software
- Software
- Drivers & Utilities, Cyberlink Medi@Show
- Included Accessories
- Power adapter, USB cable, audio / video cable
- Battery Type
- Samsung IA-BP85ST Lithium Ion
- Details
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDHC Memory Card, MultiMediaCardplus
- Image Storage
- JPEG 800 x 600
- 6 cm
- 12.5 cm
- 6 cm
- 270 g
- 0 °C
- 40 °C
