Samsung SMX-F30SP Flash Camcorder - Si
Quicklinx: 5GSHWS00 Mfr#: SMX-F30SP/XEU
  • SDHC Memory Card
Samsung's sleek Memory Card Camcorder features a powerful 42x Intelli-zoom lens and a 8th generation DSP chip, which basically delivers a whole new level of image brilliance. You can also easily share your memories on the internet and portable devices with the Web and Mobile mode. Add to this the longer battery life, and you have a camcorder that is ready to go exploring.
  • More recording time, more memories to treasure
    Enjoy recording more of the highest quality video footage with the SAMSUNG F30/33/34. Thanks to the high performing H.264 Codec, the F30/33/34 record more of your memories than camcorders which use MPEG2. With the same capacity, the F30/33/34 record about twice more than MPEG2 codec. Its compressed video files are faster to e-mail and upload to the web, which makes sharing as easy as can be, with no loss of Image quality.
  • Face detection AF technology
    Unlike conventional camcorders, the F30/33/34's advanced Face Detection AF technology targets the faces in the screen. With intelligent face detection auto-focus, faces are always focused-on, even if they are not in the centre of the screen. SAMSUNG's Face Detection AF enables you to capture clearer, higher quality video.
  • Colour as vivid as your memories
    Digital Natural Colour Processing creates an expanded palette of colours that are closer to those seen in nature. By internally adjusting images beyond RGB into 4 colour CMYG spectral colour matching, the F30/33/34 are able to accurately recreate colours that are closer to those your eyes see, closer to your memories, and closer to reality.
  • 3D noise reduction
    The F30/33/34 transcend the boundaries of convention by introducing 3D noise reduction that dramatically eliminates noise while maintaining the original edge and pattern of the image. By analysing motion between the frames, the frames are split into pattern / edge frames and differential frames and are passed through separate filters which maintain the pattern and edge and remove noise. After filtering, the frames are combined once more to make a cleaner, clearer image.
  • The 8th generation DSP chip from SAMSUNG
    Experience the most naturally beautiful images with the 8th generation DSP chip from SAMSUNG. Advanced Colour Expression, Hyper Digital Image Stabiliser, Super LCD plus, and Face Detection Auto Focus combine to make your digital image dreams a reality. Longer battery life, extended recording time, and higher quality digital imaging are enabled by the SAMSUNG chip. By designing and implementing a powerful single chip control system, power consumption is dramatically reduced, allowing you to capture more memories that can be treasured for the rest of your life.
Samsung SMX-F30 - camcorder - Schneider - storage: flash card
Camcorder
Lens Included
Schneider
Media Type
Flash card
Memory Card Slot
SD card
Sensor Resolution
800 KP
Effective Sensor Resolution
Video: 540 KP - Photo: 0.48 MP
Lens System
Zoom lens - 34x zoom - 2.3 - 78.2 mm - f/1.6-4.3
Focus Adjustment
Automatic, manual
Digital Zoom
1200x
Image Stabiliser
Electronic
Display
LCD display - 2.7"
Supported Battery
Li-ion rechargeable battery - 850 mAh (included)
Composite video/audio, USB 2.0
Silver
6 cm x 12.5 cm x 6 cm
270 g
Camcorder
Lens Included
Schneider
Enclosure Colour
Silver
Camcorder Type
Consumer
Camcorder Sensor Resolution
800 KP
Sensor Qty
1 CCD
Effective Video Resolution
540 KP
Effective Photo Resolution
0.48 MP
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
CCD
Optical Sensor Size
1/6"
Optical Zoom
34x
Digital Zoom
1200x
Image Stabiliser
Electronic
Face Detection
Services and Applications
YouTube capture mode
Digital Video Format
H.264
Image Recording Format
JPEG
Exposure & White Balance
Min Illumination
3 lux
Exposure Modes
Programme, automatic
Shooting Programs
Spotlight, portrait mode, hi-speed shutter, flowing water, food, sports mode, beach, snow
Special Effects
Negative, Art, Black & White, Sepia, Mosaic, Pastel, Mirror, Emboss, Stepprinting, cosmetic
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, daylight
Max Shutter Speed
1/10000 sec
Min Shutter Speed
1/60 sec
Lens System
Schneider zoom lens - 34x zoom - 2.3 - 78.2 mm - f/1.6-4.3
Focus Adjustment
Automatic, manual
Zoom Adjustment
Motorised drive
Filter Size
30 mm
Built-in lens shield
Additional Features
Additional Features
Built-in speaker, Backlight Compensation (BLC), auto power save, digital noise reduction, interval shooting mode
Display
2.7" LCD display
Display Format
112,000 pixels
Display Form Factor
Rotating
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Wind noise reduction
Connector Type
USB , Composite video/audio output , DC power input
Software
Software
Drivers & Utilities, Cyberlink Medi@Show
Power adapter, USB cable, audio / video cable
Battery Type
Samsung IA-BP85ST Lithium Ion
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDHC Memory Card, MultiMediaCardplus
Image Storage
JPEG 800 x 600
6 cm
12.5 cm
6 cm
270 g
