Samsung SmartThings V3 Hub (2018)
Quicklinx: DS2NWS00 Mfr#: GP-U999SJVLGEA
Connect wirelessly with a wide range of smart devices and make them work together.
  • Turn your home into a smart home with a SmartThings Hub.
  • Connect wirelessly with a wide range of smart devices and make them work together.
  • Monitor and control connected devices in your home using a single SmartThings app for iOS or Android.
  • Receive alerts from connected devices when there’s unexpected activity in your home.
  • Automate connected devices in your home and set them to turn on or off when doors are opened, as people come and go, and much more.
  • Manage connected devices in your home with SmartThings scenes for Good Morning, Goodbye, Good Night, and more.
  • Control connected devices in your home with voice commands using SmartThings and the Google Assistant or Amazon Alexa.
SmartThings works with a wide range of connected devices.
  • Voice Assistants: Use the Google Assistant and Amazon Alexa to control a wide range of connected devices with your voice. Automate multiple devices at different times of the day by using scenes for Good Morning, Goodbye, Good Night and more.
  • Lights and Switches: Set connected lights and switches from Philips Hue, Sylvania, and LIFX to turn on and off when you open doors, change brightness at the right moment, and much more.
  • Speakers: Set connected speakers from Samsung and Bose to play your favorite song when you open the front door, turn off when you leave, and much more.
  • Cameras and Doorbells: Set connected cameras and doorbells from Arlo and Ring to send you video notifications, turn on connected lights when there’s a visitor, and much more.
  • Door Locks: Set connected door locks from Yale to open when you arrive home, lock when you leave the house, and much more.
  • Thermostats: Set connected thermostats from Honeywell to turn on when you open the front door, turn off when you leave home, and much more. Look for the Works with SmartThings logo next time you’re buying a connected device for your home, or visit SmartThings.com to see the full list of compatible devices.
In the Box
  • SmartThings Hub.
  • Ethernet cable and power supply.
  • Quick-start guide and health and safety guide.
Requirements
  • Requires an internet-connected Wi-Fi router with an available Ethernet port, plus the freeSmartThings app for Android (6.0 or later) or iOS (11.0 or later).
  • Visit SmartThings.com for specifications, support, and more.
Technical Information
  • Power: In-wall power adapter.
  • Communication Protocol: Zigbee, Z-Wave, and WiFi.
  • Range: 15-40 meters depending on your home’s construction.
  • Operating Temperature: 0-40°C.
  • Dimensions: 127 x 127 x 30.5 mm.
  • Weight: 136 grams.
  • Color: White.
  • Warranty: One-year limited warranty.
  • Video capability
    Keep an eye on what matters most while you're away. Receive push notifications to live stream what's going on at home, or record video clips 30 seconds before, and for two minutes after a specified event takes place. Download recorded video clips to your smartphone, which are stored for up to 30 days.
  • Simple set-up
    Includes everything you need to get started. No wiring or instalation needed: anyone with broadband Internet connexion can easily set up their Hub and connect their devices to start easily monitoring and controlling their home from anywhere with the SmartThings smart phone app.
Samsung SmartThings Hub V3 - central controller - ZigBee, Wi-Fi, Z-Wave - white
Central controller
Power Source
Power adapter
Internet of Things (IoT) Platform
SmartThings
Wireless, wired - ZigBee, Wi-Fi, Z-Wave - Ethernet
White
1-year warranty
12.7 cm x 2.9 cm x 12.6 cm
Central controller
Power Source
Power adapter
Wireless, wired - Ethernet, USB, Z-Wave, ZigBee, Wi-Fi
Max Range Indoors
40 m
Android 6.0 (Marshmallow) or later, Apple iOS 11 or later
Interfaces Details
USB , LAN
Platform
SmartThings
Power adapter
White
Warranty
1-year warranty
12.7 cm
2.9 cm
12.6 cm
156.8 g
