Samsung SmartThings Smart Button (2018)
Quicklinx: DS2RWS00 Mfr#: GP-U999SJVLEEA
Type: Push button
Compatible With: Alexa, Google Assistant, SmartThings
37 in stock
£20.00 ex VAT
£24.00 inc VAT
Express delivery Order within the next 22 hours for delivery on Thursday
Control connected devices at the touch of a button.
  • Control lights, electronics, and small appliances.
  • Set multiple lights, electronics, and small appliances to turn on and off with the button.
  • Customize actions with a single tap, double tap, or long press.
  • Requires a SmartThings Hub or compatible device with SmartThings Hub functionality. https://www.shop.bt.com/DS2N
Add smartness to your home with a SmartThings Button. Control lights, electronics, and small appliances at the touch of a button. Also monitors temperature.
SmartThings is the easy way to turn your home into a smart home.
  • Your smart home needs a brain, so get started with SmartThings. It connects wirelessly with a wide range of smart devices and makes them work together.
  • Next, add some smart devices and put your home to work. Choose from a wide range of compatible devices, including lights, cameras, locks, thermostats, sensors, and more.
  • Finally, use the Google Assistant, Amazon Alexa, or one of the SmartThings apps to control your smart home. Teach your house new tricks by telling it what to do when you’re asleep, awake, away, and back home
In the Box
  • SmartThings Button.
  • Quick-start guide and health and safety guide.
Requirements
  • Requires the free SmartThings app for Android (6.0 or later) or iOS (10.0 or later).
  • Visit SmartThings.com for specifications, support, and more.
Technical Information
  • Power: 1 x CR2450 battery.
  • Communication Protocol: Zigbee.
  • Range: 15-40 meters depending on your home’s construction.
  • Operating Temperature: 0 to 40°C.
  • Dimensions: 40.9 x 40.9 x 14.7 mm.
  • Weight: 22.7 grams.
  • Color: White.
  • Warranty: One-year limited warranty.
Samsung SmartThings - push button
Push button
Functions
Turn electronics on/off
Power Source
Internet of Things (IoT) Platform
SmartThings
Wireless - ZigBee 3.0
White
1-year warranty
4.08 cm x 1.48 cm x 4.08 cm
Push button
Functions
Power Source
Wireless - ZigBee
Max Range Indoors
40 m
Android 6.0 (Marshmallow) or later, Apple iOS 11 or later
Platform
SmartThings
Adhesive strips
White
Battery Required
1 x CR2450
Warranty
1-year warranty
4.08 cm
1.48 cm
4.08 cm
23 g
Type: Push button
Compatible With: SmartThings
Brand: Samsung
Price Range Ex VAT: 0 - 50
