Control connected devices at the touch of a button.
- Control lights, electronics, and small appliances.
- Set multiple lights, electronics, and small appliances to turn on and off with the button.
- Customize actions with a single tap, double tap, or long press.
- Requires a SmartThings Hub or compatible device with SmartThings Hub functionality. https://www.shop.bt.com/DS2N
Add smartness to your home with a SmartThings Button. Control lights, electronics, and small appliances at the touch of a button. Also monitors temperature.
SmartThings is the easy way to turn your home into a smart home.
- Your smart home needs a brain, so get started with SmartThings. It connects wirelessly with a wide range of smart devices and makes them work together.
- Next, add some smart devices and put your home to work. Choose from a wide range of compatible devices, including lights, cameras, locks, thermostats, sensors, and more.
- Finally, use the Google Assistant, Amazon Alexa, or one of the SmartThings apps to control your smart home. Teach your house new tricks by telling it what to do when you’re asleep, awake, away, and back home
In the Box
- SmartThings Button.
- Quick-start guide and health and safety guide.
Requirements
- Requires the free SmartThings app for Android (6.0 or later) or iOS (10.0 or later).
- Visit SmartThings.com for specifications, support, and more.
Technical Information
- Power: 1 x CR2450 battery.
- Communication Protocol: Zigbee.
- Range: 15-40 meters depending on your home’s construction.
- Operating Temperature: 0 to 40°C.
- Dimensions: 40.9 x 40.9 x 14.7 mm.
- Weight: 22.7 grams.
- Color: White.
- Warranty: One-year limited warranty.
Video capability
Keep an eye on what matters most while you're away. Receive push notifications to live stream what's going on at home, or record video clips 30 seconds before, and for two minutes after a specified event takes place. Download recorded video clips to your smartphone, which are stored for up to 30 days. -
Simple set-up
Includes everything you need to get started. No wiring or instalation needed: anyone with broadband Internet connexion can easily set up their Hub and connect their devices to start easily monitoring and controlling their home from anywhere with the SmartThings smart phone app.
- Samsung SmartThings - push button - ZigBee 3.0 - white
- Product Type
- Push button
- Functions
- Turn electronics on/off
- Power Source
- Battery
- Internet of Things (IoT) Platform
- SmartThings
- Connectivity
- Wireless - ZigBee 3.0
- White
- 1-year warranty
- 4.08 cm x 1.48 cm x 4.08 cm
- Product Type
- Push button
- Functions
- Power Source
- Battery
- Connectivity Technology
- Wireless - ZigBee
- Max Range Indoors
- 40 m
- OS Required
- Android 6.0 (Marshmallow) or later, Apple iOS 11 or later
- Internet of Things (IoT) Compatible
- Platform
- SmartThings
- Form Factor
- CR2450
- Battery Included
- Required Qty
- 1
- Included Accessories
- Adhesive strips
- White
- Warranty
- 1-year warranty
- 4.08 cm
- 1.48 cm
- 4.08 cm
- 23 g
- 0 °C
- 40 °C
