Compact Pan & Tilt monitoring camera - giving you peace of mind
The new Samsung SmartCam PT is ideal for home security and peace of mind when you leave the property or go travelling. You cannot always be at home but with the SmartCam PT it provides reassurance that hopefully all is okay in the home by providing live video HD recording. Unexpected events in the home can be notified to you via your Smartphone or web viewer enabling monitoring anytime and anywhere.
Videos and images can be saved onto micro SD cards up to 128GB and stored recordings can be a big help as evidence if something has occurred whilst out. Intrusion on a dark night will also not be missed at the zones you select because it has night vision up to 5 meters allowing clear image monitoring and capturing.
High resolution video
2M (Full HD) helps you to monitor a clearer and brighter video.
Camera Pan/Tilt
You can move the camera to a desired direction (up, down, left or right) to monitor a wider area.
Privacy mode
For privacy protection, you can turn off the camera at a desired time automatically.
Auto tracking
The camera tracks a moving person or object for monitoring.
Backlight correction
The WDR (wide dynamic range) function can brighten up a dark object which has been affected by the backlight.
Motion zone detection
If you set a specific area such as entrance or windows, it can monitor movements and send alerts about that area. (max three areas can be set)
SmartCam for Baby Monitoring
Parents always want to be with their children but sometimes leaving is inevitable.
Use the SmartCam and you can always be there with them.
Be present with your family always. Whenever you can access the Internet, you can monitor your children on a PC, Mac, iPhone/Android smartphone, or on a tablet computer remotely at anytime. High-quality video and two-way audio communication allow you to keep bonded to your adorables.
This camera follows what other cameras miss
With Auto Tracking this camera will follow moving objects and capture the action.
Watch what matters most
This camera will capture amazing images. The SNH-V6410 has night vision capability which ensures it will continue to capture high-quality images in low-light conditions. -
Stay connected
You cannot always be at home and so peace of mind comes with knowing you can have a two-way conversation within anyone in close proximity to SNH-V6410 via a built-in microphone.
- Hanwha Techwin SmartCam SNH-V6410PN - network surveillance camera
- Network surveillance camera - pan / tilt
- Audio
- Yes: built-in speaker, two-way audio capability, built-in microphone
- 8.5 cm x 8.5 cm x 8.4 cm
- 155 g
- Black, dark grey
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- CMOS - 1/3" - 3 MP
- Minimum Illumination
- 0.3 lux - colour , 0 lux - B&W
- Focal Length Control
- Fixed focal
- Focal Length
- 4 mm
- Panning Range (degree)
- 360
- Tilting Range (degree)
- 155
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Voltage
- DC 5 V
- Digital noise reduction, progressive scanning, image mirror, Wide Dynamic Range (WDR), Motion Detection Technology, Privacy mode, auto white balance
- Environmental Parameters (operating)
- 0 °C - 40 °C; 0 - 90% relative humidity
- Audio Support
- Wireless
- 8.5 cm
- 8.5 cm
- 8.4 cm
- 155 g
- Localisation
- United Kingdom
Camera
- Colour - Day&Night - pan / tilt
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Digital Zoom
- 4
- Infrared LEDs
- Infrared Distance
- 5 m
- Digital Video Capture Resolution
- 1280 x 720, 1920 x 1080, 640 x 360
- Frame Rate (max)
Image Sensor
- 3 MP CMOS 1/3"
- Effective Pixels
- 1944 x 1092
Lens Construction
- Fixed focal
- Focal Length
- 4 mm
- Horizontal Field of View (degree)
- 80.9
- Vertical Field of View (degree)
- 43.4
Panning
- Range (degree)
- 360
Tilting
- Range (degree)
- 155
- Network Interface
- Network Protocols
- DHCP, DNS, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, HTTPS, UPnP, SSL
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Black, dark grey
- Power Requirements
- DC 5 V - 2 A
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 0 - 90%
