Display window at a glance
The smart view wallet case lets you access the interactive display of your Galaxy S23 ultra phone without opening the cover. -
Just simple taps will do
You can tap the display window to perform basic functions like answering the phone or pausing the music even with the cover closed. -
Carry your everyday essentials safe with your phone
The smart view wallet case lets you slide in your frequently used card inside, so you can keep it handy and safely hidden. -
Turn waste into valuable resources
While protecting your phone, you are also saving the environment. You can help preserve the Earth's precious resources by purchasing the product made with UL-certified recycled and bio materials.
- Samsung EF-ZS918 - flip cover for mobile phone
- Product Type
- Flip cover for mobile phone
- 8.32 cm x 1.46 cm x 16.74 cm
- 75 g
- Black
- Designed For
- Galaxy S23 Ultra
- 8.32 cm
- 1.46 cm
- 16.74 cm
- 75 g
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Cover Type
- Flip cover
- Open Type
- Side
- Cover Features
- Screen window
- UL
- Designed For
- Samsung Galaxy S23 Ultra
