2M (Full HD) SNH-E6440Bn camera helps you to monitor a clearer and brighter video. The visual angle of 128 degrees can provide wide monitoring coverage for your camera. If you set a specific area such as entrance or windows, it can monitor movements and send alerts about that area.
You can save your important moments in the memory card. A max 32GB memory card may be used. The recorded video can be played using your smart phone or PC viewer anytime anywhere.
It supports the Wi-Fi direct function that allows you to connect your camera to the wireless network.
Using your smartphone and SmartCam you can chat with your friends due to the built in mic/speaker units in the SmartCam.
The product is water/vibration proof (IP66), and it can be installed in an outdoor area or outside the home.
High resolution video
2M (Full HD) helps you to monitor a clearer and brighter video. -
Wide angle
The visual angle of 128 degrees can provide wide monitoring coverage for your camera. -
Motion zone detection
If you set a specific area such as entrance or windows, it can monitor movements and send alerts about that area. -
Saving in the memory card
You can save your important moments in the memory card. A max 32GB memory card may be used. The recorded video can be played using your smart phone or PC viewer anytime anywhere. -
Easy installation
It supports the Wi-Fi direct function that allows you to connect your camera to the wireless network. -
Real-time alarm
It can detect movements and sounds and sends you real time notifications on your smart phone and PC viewer. -
Bi-directional audio
Using your smartphone and SmartCam you can chat with your friends due to the built in mic/speaker units in the SmartCam. -
Night vision (5m)
In poorly lit areas, the IR LED is operated automatically to brighten dark images. -
Clear color
IR Cut Filter switches between day and night to provide clearer color images. -
Installable outside
The product is water/vibration proof (IP66), and it can be installed in an outdoor area or outside the home. -
Main body/camera detachable design
If you are outside the home in an area where Wi-Fi signals are weak, you need to install a camera and if you are at home with a strong Wi-Fi signal, then you need to install the main body, so that it can be easily used where the Wi-Fi signals are weak.
- Samsung Techwin SmartCam SNH-E6440BN - network surveillance camera
- Network surveillance camera - fixed - outdoor - waterproof
- Audio
- Yes: two-way audio capability
- 5.4 cm x 5.4 cm x 10.2 cm
- 568 g
- White
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- CMOS - 1/2.8" - 2 MP
- Minimum Illumination
- 0 lux - B&W , 0.3 lux - colour
- Focal Length Control
- Fixed focal
- Focal Length
- 2.8 mm
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Cables Included
- 1 - network cable - external
- Voltage
- DC 9 V
- Alarm function, progressive scanning, image flip, image mirror, Motion Detection Technology, multi-streaming, Intelligent Video Analysis (IVA), Audio Detection, Motion Zone Alert, auto white balance, Wi-Fi Direct
- Environmental Parameters (operating)
- -10 °C - 50 °C; 0 - 90% relative humidity
- Audio Support
- Wired, wireless
- 5.4 cm
- 5.4 cm
- 10.2 cm
- 568 g
Camera
- Colour - Day&Night - fixed - outdoor - waterproof
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Digital Zoom
- 4
- Infrared LEDs
- Infrared Distance
- 15 m
- Video Capture
- 1920 x 1080 @ 30 fps
- Supported Image Formats
- JPEG
Image Sensor
- 2 MP CMOS 1/2.8"
- Effective Pixels
- 1944 x 1224
Lens Construction
- Fixed focal
- Focal Length
- 2.8 mm
- Horizontal Field of View (degree)
- 111
- Vertical Field of View (degree)
- 62
- Network Interface
- Network Protocols
- DHCP, DNS, HTTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, UPnP, IPv4, Bonjour, RTCP, SSL, SNTP
- Ports
- LAN - RJ-45 , Audio line out , Audio line-in/microphone
- Supported Memory Cards
- microSD Card, microSDHC Card
- Included Accessories
- Mounting kit
- Cables Included
- 1 x network cable - external
- IP66
- White
- Power Requirements
- DC 9 V - 1 A
- Power Device
- Power adapter 9 Watt
- OS Required
- Apple MacOS X 10.7 or later, Android 4.x, Microsoft Windows XP / 7 / 8 or later, Apple iOS 6.x or later
- -10 °C
- 50 °C
- Relative Humidity (operating)
- 0 - 90%
