Samsung SH-S222 22x DVD-RW SATA OEM (Black)
Quicklinx: 7WXQWS00 Mfr#: SH-222BB/BEBE
Samsung 22x DVD writer features fast speed with green concept. Fast lead in, low noise, low power consumption, light weight. Always at the forefront of speed technology, Samsung produces high speed DVD writers. Enhanced and enabled by Samsung WriteMaster technology, this lightning quick writer intuitively detects the media type and automatically writes in the optimal speed for the disc. So all you have to do is just click to burn your disc. But don't walk away - it'll be done before you have a chance to make a cup of coffee.
Whether it's kicking into high rotation speed or performing low speed operations such as direct disc labeling, Samsung's DVD writer reduces noise and vibration while ensuring reliable disc writing. It even checks the quality of each inserted disc and intuitively alters the laser power on the inner and outer sides accordingly. And to help achieve reliable writing, this trusty DVD writer tilts the objective lens when the disc isn't flat.
  • Blazing speed makes this DVD writer a trailblazer
  • Engineered for extreme reliability
  • Low power consumption
    How low can it go? Samsung's ultra-reliable, easy-to-use, easy-to-install DVD writer not only reduces heat, and its unique aerodynamic frame was also engineered to reduce acoustic and airborne noise by preventing pressure concentration in specific areas. This dynamic DVD writer delivers high performance.
  • Speed Adjustment technology
    Samsung's intelligent WriteMaster technology intuitively detects the media type and automatically writes in the optimal speed for the disc. So all you have to do is just click to burn your disc.
  • SpeedPlus
    SpeedPlus power speed technology delivers really fast recording speeds. And with its low noise and vibration control system for high speed writing, the job is always quiet and smooth.
Samsung Super-WriteMaster SH-222BB - DVD±RW (±R DL) / DVD-RAM drive - Serial ATA - internal
DVD±RW (±R DL) / DVD-RAM drive - internal
Serial ATA
14.8 cm x 17 cm x 4.2 cm
0.75 kg
Optical Storage
DVD±RW (±R DL) / DVD-RAM - 5.25" x 1/2H
Read Speed
48x (CD) / 16x (DVD)
Write Speed
48x (CD) / 22x (DVD±R) / 8x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
Buffer Underrun Protection
Media Load Type
Tray
Microsoft Certification
Compatible with Windows 7
Serial ATA
14.8 cm
17 cm
4.2 cm
0.75 kg
Optical Storage
Read Speed
Write Speed
Supported Media Formats
CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Mixed-mode CD, Photo CD, Video CD, CD-ROM, DVD-Video
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
Media Load Type
Tray
Access Time
130 ms (CD), 150 ms (DVD)
Buffer Size
1.5 MB
Automatic Ball Balancing System (A.B.S), horizontal/vertical mountable, Speed Adjustment Technology (SAT), Tilt Actuator Compensation (TAC), Double Optimum Power Control, Writemaster Technology, firmware upgradable, Weight Balance System Techonology (WBS), Magic Speed, Speed Plus
Video CD
1 x Serial ATA-150
Compatible Bay
1 x 5.25" x 1/2H - front accessible
RoHS, WEEE
Package Type
Bulk
Microsoft Windows 2000/XP/Vista/7
System Requirements Details
Windows 2000/XP/Vista/7 - Pentium 4 - 2 GHz - RAM: 256 MB
5 °C
50 °C
20 - 80%
