Desktop Replacement for an Optimised Experience
The Samsung All-in-One is the ambience setter. Combining sleek design with the ultimate user experience. It makes an ideal desktop replacement or as a contemporary styling for your office/reception area.
Control Your PC By Hand
5 hand gesture recognition functions conveniently let you stay in control with just a flick of the wrist from 1 metre away. Just issue commands with a simple hand gesture.
Even More Control At Your Fingertips
An advanced 10-finger multi-touch capability provides a technological leap in interactivity, surpassing traditional two-finger multi-touch by providing full touch control using all 10 fingers. Its enhanced sensitivity means you can enjoy the full capabilities of the latest entertainment applications and do complicated editing, as you can pinch-to-zoom, rotate images, and scroll through pages with complete ease using 10 multi-touch functions.
A Clearer Picture Almost Anywhere
Enjoy consistently superior picture clarity at any angle within 170 degrees horizontally and 160 degree vertically without any colour distortion thanks to innovative wide viewing angle technology.
Rich & Immersive Sound
14 watt speakers with Tweeter and SoundAlive bring you a rich sound quality that's optimized for home entertainment. The Tweeter's ability to play high frequency sounds creates a more realistic experience, while SoundAlive generates a powerful sound quality. So you have the perfect way to enjoy a movie or music with the Samsung AIO Series 5.
Designed To Enhance
Accentuate your environment with a retro style look. Its clutter-free and space-saving design features a unique 4 way stand and an edge to edge glossy black screen with a durable metal edge.
Zero Depth Bezel For Maximum Usability
With the advent of Windows 8 even more functions have been introduced to enhance the touch experience, such as swiping the screen's edge to call-up the system or application menu. A fully fl at screen with a zero depth bezel ensures the perfect touch experience, including edge swiping.
The Key To Getting More Done
When working on documents the keyboard and mouse are used together. So a space-effi cient keyboard without numeric keys makes typing and using the mouse much easier and more comfortable by creating more room. Useful Windows 8 hot keys, including a Windows 8 Charm Bar, also provide faster access to frequently used functions*.
A functional work of art
Beautifully designed to be put on display, the Series 5 All-In-One PC just became the new centerpiece of home computing and entertainment. Pairing a brilliant HD screen with innovative touch and gesture technology, you can easily browse the web, send email, watch multimedia, and play video games - everything - which is how the Series 5 All-In-One PC lives up to its name. -
Control your PC as never before
Browse the web, write and send email, chat with friends and more with touchscreen and gesture control technology. Featuring a 21.5-inch multi-touch-screen that can detect up to 10 points of contact, the All-In-One PC makes computing easier and more efficient than ever. -
Live connected with AllShare play
Now you can connect your All-In-One PC with multiple compatible devices via the internet. Use S Manager to download AllShare Play to share content to and from a Samsung Smart TV, smartphone or camera using AllShare Play. Featuring an 500GB hard drive to store all your movies, videos and more, you can even use the unique wake-up function to access content remotely, while your All-In-One PC is asleep. -
Personalized and more productive
The most commonly used features are designed to be fast, simple and completely controlled by you. Networks, sound and display settings can all be changed with a simple touch of the screen. Adjust power settings to improve battery life and productivity without sacrificing performance. And switch between touch screen interaction and the included wireless keyboard and mouse and use it as a conventional PC. -
Discover the new, beautiful, fast and fluid Windows 8
Reimagined to be all about you, Windows 8 lets you personalize your desktop and gives you instant access to all your favorite people, apps, sites and more. Use S Manager to keep your PC running smoothly with the latest software and drivers, and to download Samsung's Quick Starter feature, which adds a toolbar and start button for easy navigation. Plus, connect to SkyDrive and store files, photos, videos and more, so wherever you go, you're connected to the cloud.
- Series
- 5 ALL IN ONE
- Product & Code Name
- 500A / Hero 21
- Part number
- DP500A2D-A02UK
- Operating System
- Genuine Windows® 8 Professional (64 Bit)
- Lid Colour
- White
- Processor
- Intel® Core⢠i5-3470T Processor (2.90 GHz, 3 MB)
- Display
- 21.5" LED Full HD (1920 x 1080) 16:9, Multi Touch
- Memory
- 4GB (DDR3 1600MHz/4GB X 1)
- Max Memory
- 8GB
- Storage
- 500GB (5400rpm SATA2)
- Optical
- DVD Super Multi Dual Layer
- Graphics
- Intel® HD Graphics 4000, graphics memory Shared with System Memory
- Speakers
- 14 W Stereo Speaker (7 W x 2)
- Wired Lan
- 10/100/1000 Gigabit Ethernet LAN
- Wireless Standard
- 802.11bgn
- 3G HSDPA
- N/A
- Card Reader
- 3-in-1 (SD, SDHC, SDXC)
- Ports
- HDMI, Headphone, Microphone In, Internal Mic, 1 x USB 3.0 (Chargeable USB), 1 x USB 3.0, 3 x USB 2.0
- Web Cam
- 720p HD Web Camera
- Dimensions
- 532.5 x 165.6 x 408.7mm, Weight: 7.9Kg
- Packaged Dimensions
- 730 x 505 x 200mm, Weight: 11Kg
- Warranty
- 1 year Collect & Return
