Samsung Series 2 - 200B5A - Core i3-380M - 2GB 320GB Windows 7 Professional - 15.6" Laptop
Quicklinx: 7G3DWS00 Mfr#: NP200B5A-A02UK
  • Core i3
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
Samsung Series 2 Business Laptop
Designed for businesses that demand long-lasting value, the Samsung series 2 notebook delivers superior reliability, security and power - at an affordable price. Its rugged, anti-shock Duracase Pro chassis is a safe haven for the very latest high performance technology - including an Intel Core processor. It also incorporates a 180 degree metal hinged anti-reflective screen that's up to 40% brighter than conventional displays, so it's much easier to use for longer - even outdoors - without your eyes getting tired. Plus Samsung's intelligent PowerPlus battery charging technology ensures that the battery retains 80% of its capacity for 3 times longer than a typical battery, making it more economical and environmentally friendly. And to optimize productivity there's a range of ergonomic features, like a responsive keyboard that's as comfortable as a desktop keyboard and a much larger touchpad with easy to use buttons. So for enduring reliability, performance and value the Samsung series 2 notebook really is the business.
  • Engineered to last
    Protect productivity and reduce costs with a robust Duracase Pro chassis. It's proven to withstand up to 500kg force on the display enclosure and accidental drops of 76cm. The anti-shock HDD with free fall sensor can also survive drops over 76cm. A Spill-resistant keyboard protects against fluid damage, while solid metal alloy hinges last much longer.
  • PowerPlus battery
    Samsung's intelligent battery charging technology enables the battery to keep 80% of its original capacity for up to 1,000 recharges - that's up to 3x longer than a typical battery, which is normally just over 300 cycles. So it's more economical and environmentally friendly as fewer batteries need to be replaced over the lifecycle.
  • Ergonomic assurance
    Enjoy easier typing and fewer errors using a responsive keyboard, ergonomically designed with optimized key sizes and spacing so it feels as comfortable as using a desktop keyboard. It also features a larger touchpad, that's bigger than other notebooks, with keyboard type buttons so you can work even faster and smarter.
  • Quick and simple expansion
    Save time and connect a range of other devices, such as a larger monitor, regular keyboard and mouse, printer and extra ports, with one simple click using the integrated docking station connector. There's no mess of cables, so when you need to move just grab the notebook - and go!
  • 180 degree hinged SuperBright LED Display
    The 180 degree metal hinged anti-reflective LED display has no mirror effect and produces the sharpest images with 300nit brightness, which is up to 40% brighter than normal laptops. Get outstanding picture quality and text readability, even when you're outdoors. And that means you can work longer without straining your eyes.
  • Powered to perform
    Get things done fast with blistering processing power and graphics performance - using state-of-the-art Intel Core processor technology and Intel HD graphics. Experience faster office tasks and web browsing, even for the most demanding applications, and enjoy a more productive and a happier workforce.
  • Fast Start
    Instant on - get started within a few seconds of opening the display or pressing the power button. An innovative hybrid sleep mode combines the fast start-up of sleep with the stability of hibernation, so you don't have to wait 30-60 seconds for the notebook to boot-up.
Samsung Series 2 200B5A A02 - 15.6" - Intel Core i3 - 380M - 2 GB RAM - 320 GB HDD
Notebook
Operating System
Win 7 Pro 64-bit
Intel Core i3 380M / 2.53 GHz / 3 MB Cache
2 GB DDR3
Storage
320 GB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics
Integrated Webcam
802.11b/g/n, Bluetooth 3.0 EDR, Gigabit Ethernet
6-cell
37 cm x 24.8 cm x 3.5 cm
2.5 kg
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - 1 year , International warranty - 1 year
Notebook
Operating System
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Chipset
Mobile Intel HM55 Express
Hyper-Threading Technology, Intel Virtualization Technology
RAM
2 GB
Max RAM Supported
8 GB
DDR3 SDRAM
Speed
1066 MHz / PC3-10600
Rated Speed
1333 MHz
SO-DIMM 204-pin
Slots Qty
2
Storage
Main Storage
320 GB HDD SATA 3Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
SuperBright, anti-reflective
Audio & Video
Graphics Processor
Intel HD Graphics
Memory Allocation Technology
Dynamic Video Memory Technology 5.0
Camera
Resolution
1.3 Megapixel
Sound
Stereo speakers
High Definition Audio
Input
Keyboard, touchpad
Communications
Wireless
Network Interface
Gigabit Ethernet
6-cell Lithium Ion
AC Adapter
Input
Output
60 Watt, 19 V, 3.16 A
Connections & Expansion
Interfaces Details
3 x USB 2.0 , Microphone input , Headphone output , HDMI , LAN , USB 2.0/eSATA , VGA
Memory Card Reader
7 in 1 (SD Card, Memory Stick, Memory Stick PRO, MultiMediaCard, xD-Picture Card, MMCplus, SDHC Card)
Software
Software Included
Adobe Acrobat Reader, Samsung Update Plus, SAMSUNG Support Center, Samsung Easy Battery Manager, Samsung Easy Network Manager, Samsung Easy Display Manager, Samsung Easy File Share, Norton Internet Security (60 days trial)
Security lock slot (cable lock sold separately), system password, hard drive password, USB Sleep-and-charge ports
Localization
2.5 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
