Link wirelessly from external storage devices to your tablets, smart phones, and smart TVs.
- Your Favorite DVD Movies & Music CDs: Enjoy viewing your favorite DVDs and listening to your CDs on your tablets and smartphones wirelessly. the "mobile Smart Hub" application can be downloaded from the Appstore, Android Market, and Amazon.
- Streaming Content Made Easy: Streaming content on your Samsung Optical SMART Hub has never been easier. With the Samsung Optical SMART Hub.
- Enjoy AllShare: The AllShare application can be used on your Samsung Smart TV, tablets, and smartphones. The AllShare application allows you to enjoy wirelessly all your stored content from your Samsung Optical Smart Hub.
- Access Your Files Wirelessly: Samsung Optical SMART Hub enables you to access your files wirelessly - wherever you are. No need to transfer files to your tablets and smartphones using your PC. Simple plug your USB storage into the Samsung Optical SMART Hub and instantly access files from your tablets and smartphones wirelessly.
- Simple File Management: Easily manage your stored files from your tablets, smartphones,and PCs. Simply move, rename, copy, paste, or delete your files in any connected storage wirelessly. Your Samsung Optical SMART Hub acts as an additional network storage.
- Always Be Connected: Samsung Optical SMART Hub allows your tablets and smartphones internet accessibility always - even while streaming data (music, movie, photos, etc.).
- Connect 4 Devices Simultaneously: Your Samsung Optical SMART Hub supports 4 devices at a same time. Whether you are watching a movie DVD movie, listening to a CD, two devices can play two different tracks on the same discs simultaneously.
- Windows 7 compatibility: The Samsung Slim External DVD Writer was engineered for ultra-compatibility, including Windows 7.
Your favorite DVD movies and music CDs
Enjoy viewing your favorite DVDs and listening to your CDs on your tablets and smartphones wirelessly. the "mobile Smart Hub" application can be downloaded from the Appstore, Android Market, and Amazon. -
Streaming content made easy
Steaming content on your Samsung Optical SMART Hub has never been easier. -
Enjoy AllShare
The AllShare application can be used on your Samsung Smart TV, tablets, and smartphones. The AllShare application allows you to enjoy wirelessly all your stored content from your Samsung Optical Smart Hub. -
Access your files wirelessly
Samsung Optical SMART Hub enables you to access your files wirelessly - wherever you are. No need to transfer files to your tablets and smartphones using your PC. Simple plug your USB storage into the Samsung Optical SMART Hub and instantly access files from your tablets and smartphones wirelessly. -
Simple file management
Easily manage your stored files from your tablets, smartphones, and PCs. Simply move, rename, copy, paste, or delete your files in any connected storage wirelessly. Your Samsung Optical SMART Hub acts as an additional network storage. -
Always be connected
Samsung Optical SMART Hub allows your tablets and smartphones Internet accessibility always - even while streaming data (music, movie, photos, etc.). -
Connect 4 devices simultaneously
- Samsung optical SmartHub SE-208BW - network drive
- Network drive
- Host Connectivity
- USB 2.0 / Ethernet 10/100 / 802.11g
- 15 cm x 19.8 cm x 2.5 cm
- 430 g ()
- Optical Storage
- 1 x DVD±RW (±R DL) / DVD-RAM - 24x (CD) / 8x (DVD±R) / 8x (DVD±R DL) (read) / 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL) / 5x (DVD-RAM) (write) / 24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) (rewrite)
- Networking
- Network adapter 10Mb LAN, 100Mb LAN, 802.11b/g
- Network drive
- Host Connectivity
- 15 cm
- 19.8 cm
- 2.5 cm
- 430 g ()
- Enclosure Colour
- White
Optical Storage
- Read Speed
- Write Speed
- 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL) / 5x (DVD-RAM)
- CD / DVD Rewrite Speed
- 24x (CD) / 6x (DVD-RW) / 8x (DVD+RW)
- Network adapter
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 802.11b/g
- PPPoE, iSCSI, FTP, DHCP, CSMA/CD
- Wireless Distribution System (WDS) support, firmware upgradable, Samba support, static IP mode
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP
- DLNA CERTIFIED
- 1 x USB 2.0 , 1 x Ethernet 100Base-TX - RJ-45
