Samsung SCX-4623FW Mono Laser Wireless Multi Functional Printer - Print, Scan, Fax, & Copy
Quicklinx: 75JCWS00 Mfr#: SCX-4623FW/SEE
Samsung printers are compactly designed, offering a stylish look that's compatible with all small office and home office working environments. This robust and durable model is reliable even in the most intensive office environments. Low noise levels are an added advantage with reduced interference and vibration in your workplace, therefore avoiding any unnecessary distractions.
This device uses enclosed 250-sheet paper input cassettes that reduce user intervention and the need to frequently replenish paper. Selecting Toner Save Mode allows you to use less toner on each page. This extends toner cartridge life by up to 30%, reduces your cost-per-page, lowers user intervention and helps to meet environmental standards.
Not only does the ultra-versatile SCX-4623FW let you print, scan, copy, and fax, it connects you to your wireless network with its one-touch Wi-Fi setting button.
  • Capture what catches your eye
    Samsung's AnyWeb Print software lets you go hunting and gathering on the Web. You can utilise the SCX-4623FW to easily select, drag and drop content from different web pages onto a printable scrap board in your browser window, all while you surf. It's the easy way to collect, arrange and edit those useful reference points and resources you can only find on the Internet for that big project – or just for fun.
  • No strings attached
    Turn your computer loose with wireless printing. There are no more cables tripping you up or plugging and unplugging machines to identify the right printer. And better yet, a wireless printer can be shared by many computers, saving you money on hardware and energy costs. Break free from the restraints of cables with the SCX-4623FW laser printer.
  • Setup is a cinch withsecure, one-touch wireless connection
    The SCX-4623FW's Wi-Fi Protected Setup button lets you connect quickly and easily. Simply select the WPS button on the access point (router), press the WPS button on the printer and you're done. Normally, you would have to spend time creating a wireless network name and manually entering a security key or password on all the wireless devices. But the ultra-convenient WPS button automatically configures - and protects - your wireless network for you.
  • It turns your PC into a fax machine
    From lunch specials to important documents, the SCX-4623FW makes sending and receiving faxes a cinch. It can deliver and save received fax data in a folder on your PC as well as change document files to image files so you can send faxes from your desk – saving toner, paper and energy. Now that's efficiency.
  • It multi-tasks so you don't have to
    Productivity is key to running any office or professional workgroup. And the versatile SCX-4623FW was designed to deliver exactly that. Now you can print, copy, scan, fax and PC-fax with unparalleled convenience, ease and speed. Why cram a corner of your office with several different machines when all you need is one central device – the 4-in-1 SCX-4623FW laser multifunction printer.
Samsung SCX-4623FW - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
12000 impressions
Max Copying Speed
Up to 22 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 22 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 1200 dpi
Original Size
216 x 356 mm (max)
Original Type
Sheets
Document Feeder Capacity
40 sheets
Media Size
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards
Standard Media Capacity
250 sheets
Output Trays Capacity
80 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi
41.6 cm x 40.9 cm x 27.6 cm
14.8 kg
Microsoft Certification
Works with Windows Vista
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
12000 impressions
Display
2 lines x 16 characters
USB 2.0, LAN, Wi-Fi
Standard Memory
128 MB 128 MB
Copying
Max Copying Speed
Up to 22 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
ID Card Copy
Printing
Max Printing Speed
Up to 22 ppm
Printer Drivers / Emulations
SPL
First Print Out Time B/W
10 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 225 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
200 station(s)
Delayed Transmission
Document & Media Handling
Max Original Size
216 x 356 mm
Original Type
Sheets
40 sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm)
250 sheets
80 sheets
Paper cassette - 250 sheets , Output tray - 80 sheets , ADF - 40 sheets - 216 x 356 mm
Speed Details
Copying: up to 22 ppm (A4) , Printing: up to 22 ppm (A4)
1 x USB 2.0 , 1 x LAN
Operating System Support
MS Windows XP, MS Windows 2000, Linux, MS Windows Server 2003, Apple Mac OS X 10.3 - 10.6, MS Windows Vista, MS Windows Server 2008
First Copy Out Time B/W
15 sec
Consumables Included
1 x toner cartridge (black)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Limited warranty - parts and labour - 1 year - on-site
41.6 cm
40.9 cm
27.6 cm
14.8 kg
Sound Emission
50 dB (operating)
