Samsung SAMSUNG SERIES 9 NOTEBOOK ETHERNET ADAPTOR
Quicklinx: 83BXWS00 Mfr#: AA-AE0NAMB
Enhance your notebook PC's connectivity with access to wired local area networks. A genuine Samsung Ethernet adapter dongle allows quick and easy access to LANs, giving you the connections you need for work or recreation. The Samsung AA-AE0NAMB LAN dongle is designed for use with Samsung series 9 notebook PCs and optimized so that you can get the most from all your devices. Just plug in and get connected.
  • Stay connected
    Extend the communication capabilities of your Samsung notebook series 9 with a LAN dongle that lets you connect to a wired LAN. Simply plug it into your Samsung LAN dongle port and you can instantly connect to the network using a standard RJ45 Ethernet cable.
Model Code
AA-AE0NAMB
Feature
LAN dongle allow you to connect to wired LAN
