Discover the Samsung S43BM700UU, a monitor that redefines standards of visual and functional performance. With its 43-inch 4K display, this monitor brings every detail to life in stunning clarity and vibrant colors, supported by HDR10 technology for a truly immersive viewing experience. The flat front bezel design and tilt adjustments ensure that you can find the perfect angle for work or play, while the LED backlight enhances image brightness and contrast.
Connectivity is a breeze with built-in Bluetooth 4.2, Wi-Fi, and a USB 2.0 hub, allowing for seamless integration with your devices. The monitor also supports features like Samsung DeX, enabling a desktop experience when connected to your smartphone, and Remote Access for working on files from the cloud directly on your monitor. Entertainment is never far away with Smart Hub, offering easy access to streaming services, and Adaptive Sound, which adjusts audio settings for an optimal listening experience.
For the professional seeking a monitor that caters to both work and play, the Samsung S43BM700UU offers a blend of performance, connectivity, and smart technology. Whether you're editing high-resolution videos, enjoying your favorite games, or simply browsing the web, this monitor is designed to elevate every aspect of your digital life.
- Samsung S43BM700UU - M70B Series - LED monitor - 4K - 43" - HDR
- LED-backlit LCD monitor - 43" - Smart monitor
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1114569
- Energy Class
- Class G
- Energy Consumption per Year
- 95 kWh
- Wi-Fi, USB 2.0 hub, Bluetooth 4.2 adapter, USB PD 65 Watt
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 5000:1
- HDR Capable
- HDR10
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 1 billion colours
- Input Connectors
- 2xHDMI, USB-C
- Tilt
- Voltage
- AC 100-240 V (50/60 Hz)
- Black
- 96.55 cm x 24.72 cm x 62.93 cm
- 10.6 kg
- CEC
- 3-year warranty
- Display Type
- LED-backlit LCD monitor / TFT active matrix - Smart monitor
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- 95 kWh
- Diagonal Size
- 43"
- Built-in Devices
- USB Power Delivery
- 65 Watt
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- 5000:1
- HDR Format
- HDR10
- Colour Support
- 1 billion colours
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- OSD Languages
- Brazilian Portuguese, German, French, Italian, Spanish, Korean, UK English, US English, English (India)
- Game mode, ConnectShare, Smart Hub, Flicker Free technology, Eye Saver Mode, Factory Tunning, DLNA, Auto Source Switch+, Adaptive Picture, Ultrawide Game View, Tizen Platform, Tap View, Remote Access, Sound Mirroring, SmartThings App Support, Adaptive Sound, Game Bar 2.0, far-field voice interaction
- Black
- 96.55 cm x 24.72 cm x 62.93 cm - with stand
- 10.6 kg
Audio
- Speakers
- 2 x HDMI , USB-C (power up to 65W) , 3 x USB 2.0
Mechanical
- Tilt
- Tilt Angle
- -2/+20
- VESA Mounting Interface
- 200 x 200 mm
- AirPlay, screen mirroring, Samsung DeX, Bixby Voice Assistant, Amazon Alexa Voice Assistant
- Included Accessories
- Remote control
- Cables Included
- 1 x HDMI cable
- CEC
- Input Voltage
- Power Consumption SDR (On mode)
- 65 kWh/1000h
- Power Consumption HDR (On mode)
- 125 kWh/1000h
- Power Consumption (Typical)
- 65 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Microsoft 365
- Dimensions & Weight Details
- With stand - width: 96.55 cm - depth: 24.72 cm - height: 62.93 cm - weight: 10.6 kg , Without stand - width: 96.55 cm - depth: 2.57 cm - height: 55.98 cm - weight: 8.5 kg
- Shipping Width
- 119.8 cm
- Shipping Depth
- 15.9 cm
- Shipping Height
- 67.7 cm
- Shipping Weight
- 13.7 kg
- Limited warranty - 3 years
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
