Samsung Samsung LS43BM700UUXXU Monitor 109.2 cm (43") 3840 x 2160 4K
Quicklinx: H6GSWS00 Mfr#: LS43BM700UUXXU
£413.94 ex VAT
£496.72 inc VAT
Discover the Samsung S43BM700UU, a monitor that redefines standards of visual and functional performance. With its 43-inch 4K display, this monitor brings every detail to life in stunning clarity and vibrant colors, supported by HDR10 technology for a truly immersive viewing experience. The flat front bezel design and tilt adjustments ensure that you can find the perfect angle for work or play, while the LED backlight enhances image brightness and contrast.
Connectivity is a breeze with built-in Bluetooth 4.2, Wi-Fi, and a USB 2.0 hub, allowing for seamless integration with your devices. The monitor also supports features like Samsung DeX, enabling a desktop experience when connected to your smartphone, and Remote Access for working on files from the cloud directly on your monitor. Entertainment is never far away with Smart Hub, offering easy access to streaming services, and Adaptive Sound, which adjusts audio settings for an optimal listening experience.
For the professional seeking a monitor that caters to both work and play, the Samsung S43BM700UU offers a blend of performance, connectivity, and smart technology. Whether you're editing high-resolution videos, enjoying your favorite games, or simply browsing the web, this monitor is designed to elevate every aspect of your digital life.
Samsung S43BM700UU - M70B Series - LED monitor - 4K - 43" - HDR
LED-backlit LCD monitor - 43" - Smart monitor
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1114569
Energy Class
Class G
Energy Consumption per Year
95 kWh
Wi-Fi, USB 2.0 hub, Bluetooth 4.2 adapter, USB PD 65 Watt
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
5000:1
HDR Capable
HDR10
Response Time
4 ms (grey-to-grey)
Colour Support
1 billion colours
Input Connectors
2xHDMI, USB-C
Display Position Adjustments
Tilt
Voltage
AC 100-240 V (50/60 Hz)
96.55 cm x 24.72 cm x 62.93 cm
10.6 kg
CEC
3-year warranty
Display Type
LED-backlit LCD monitor / TFT active matrix - Smart monitor
Energy Class
Class G
Energy Class (HDR)
Class G
95 kWh
Diagonal Size
43"
Built-in Devices
USB Power Delivery
65 Watt
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
5000:1
HDR Format
HDR10
Colour Support
1 billion colours
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Brazilian Portuguese, German, French, Italian, Spanish, Korean, UK English, US English, English (India)
Game mode, ConnectShare, Smart Hub, Flicker Free technology, Eye Saver Mode, Factory Tunning, DLNA, Auto Source Switch+, Adaptive Picture, Ultrawide Game View, Tizen Platform, Tap View, Remote Access, Sound Mirroring, SmartThings App Support, Adaptive Sound, Game Bar 2.0, far-field voice interaction
96.55 cm x 24.72 cm x 62.93 cm - with stand
10.6 kg
Audio
Speakers
2 x HDMI , USB-C (power up to 65W) , 3 x USB 2.0
Mechanical
Tilt
Tilt Angle
-2/+20
VESA Mounting Interface
200 x 200 mm
AirPlay, screen mirroring, Samsung DeX, Bixby Voice Assistant, Amazon Alexa Voice Assistant
Remote control
1 x HDMI cable
CEC
Input Voltage
65 kWh/1000h
Power Consumption HDR (On mode)
125 kWh/1000h
Power Consumption (Typical)
65 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Microsoft 365
Dimensions & Weight Details
With stand - width: 96.55 cm - depth: 24.72 cm - height: 62.93 cm - weight: 10.6 kg , Without stand - width: 96.55 cm - depth: 2.57 cm - height: 55.98 cm - weight: 8.5 kg
Shipping Width
119.8 cm
Shipping Depth
15.9 cm
Shipping Height
67.7 cm
Shipping Weight
13.7 kg
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
Brand: Samsung
