Discover the perfect blend of form and function with the Samsung ViewFinity S7, a 32-inch LED-backlit LCD monitor that brings your content to life in breathtaking 4K resolution. With a color gamut covering 99% of the sRGB spectrum and support for over 1 billion colors, this monitor delivers precise and vibrant visuals for any application. The ergonomic design allows for tilt adjustments, ensuring comfort during long work sessions or immersive gaming marathons. Connectivity is seamless, thanks to a variety of ports including HDMI and DisplayPort, making it easy to hook up all your devices. Additionally, the ViewFinity S7 is equipped with features like Eye Saver Mode and Flicker-Free technology, minimizing eye strain for a more comfortable viewing experience. Energy efficiency is also a key aspect of this monitor, with ENERGY STAR and TCO certifications highlighting its eco-friendly performance. Whether for professional use or entertainment, the Samsung ViewFinity S7 is a smart choice for those who demand high quality and functionality.
- Samsung ViewFinity S7 S32A700NWP - S70A series - LED monitor - 4K - 32"
- LED-backlit LCD monitor - 32"
- Energy Class
- Class G
- Energy Consumption per Year
- 46 kWh
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 2500:1
- Response Time
- 5 ms
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort
- Tilt
- Voltage
- AC 100-240 V
- Black
- 71.61 cm x 19.35 cm x 51.85 cm
- 6.1 kg
- Environmental Standards
- TCO Certified Displays 9, ENERGY STAR Qualified
- TUV Rheinland
- 2-year warranty
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- 46 kWh
- Diagonal Size
- 32"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- 2500:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Picture by picture, game mode, Eco Light Sensor, CustomColor Mode, Mega Infinity Dynamic Contrast Ratio, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, sRGB Mode, Picture-in-Picture, 3-side virtually borderless display, Dynamic Contrast Mode, Adaptive Picture, High Bright mode, Auto Source Switch
- Black
- 71.61 cm x 19.35 cm x 51.85 cm - with stand
- 6.1 kg
- DisplayPort 1.2 , HDMI , Headphones (mini-jack) , USB
Mechanical
- Tilt
- Tilt Angle
- -2/+22
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), 3% recycled plastic
- Cables Included
- 1 x HDMI cable
- TUV Rheinland
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 100-240 V
- Power Consumption SDR (On mode)
- 33.2 kWh/1000h
- Power Consumption HDR (On mode)
- 51 kWh/1000h
- Power Consumption (Typical)
- 33.2 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 71.61 cm - depth: 19.35 cm - height: 51.85 cm - weight: 6.1 kg , Without stand - width: 71.61 cm - depth: 4.13 cm - height: 42.47 cm - weight: 5 kg
- Shipping Width
- 84.2 cm
- Shipping Depth
- 13.3 cm
- Shipping Height
- 48.7 cm
- Shipping Weight
- 8 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - 2 years
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
