Discover a truly immersive viewing experience with the Samsung monitor curved more deeply than any other. Wrapping around your field of vision like your local iMax theater screen, the 1800 R screen - with its 1800 mm radius of arc for greater curvature - creates a wider field of view, enhances depth perception, and minimizes peripheral distractions to draw you deeper in to your content. So whether it is an online movie, a favorite TV show or a pulse-racing game, Samsung's deeper screen curve will fully immerse you in all your multi-media content.
- Samsung C24F390FHR - CF39 Series - LED monitor - curved - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/401461
- Energy Class
- Class E
- Energy Consumption per Year
- 26 kWh
- Power Consumption (On mode)
- 18 W
- Curved Screen
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (NTSC 1976)
- Input Connectors
- HDMI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Black
- 54.78 cm x 20.65 cm x 41.82 cm
- 3.3 kg
- Display Type
- Energy Class
- Class E
- 26 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.5"
- Curved Screen
- Yes (1800R)
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Colour Gamut
- 72% (NTSC 1976)
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode
- Black
- 54.78 cm x 20.65 cm x 41.82 cm - with stand
- 3.3 kg
- VGA , HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -2/+22
- VESA Mounting Interface
- 75 x 75 mm
- Cables Included
- 1 x HDMI cable
- Input Voltage
- AC 120/230 V
- 18 W
- Power Consumption SDR (On mode)
- 18 kWh/1000h
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 54.78 cm - depth: 20.65 cm - height: 41.82 cm - weight: 3.3 kg , Without stand - width: 54.78 cm - depth: 8.76 cm - height: 32.63 cm - weight: 2.8 kg
- Shipping Width
- 61.8 cm
- Shipping Depth
- 16.6 cm
- Shipping Height
- 39.4 cm
- Shipping Weight
- 4.7 kg
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
