Samsung Samsung CF390 24" 1920 x 1080 pixels 4 ms FHD LED Black
Quicklinx: H7PKWS00 Mfr#: LC24F390FHRXXU
£129.34 ex VAT
£155.20 inc VAT
Discover a truly immersive viewing experience with the Samsung monitor curved more deeply than any other. Wrapping around your field of vision like your local iMax theater screen, the 1800 R screen - with its 1800 mm radius of arc for greater curvature - creates a wider field of view, enhances depth perception, and minimizes peripheral distractions to draw you deeper in to your content. So whether it is an online movie, a favorite TV show or a pulse-racing game, Samsung's deeper screen curve will fully immerse you in all your multi-media content.
Samsung C24F390FHR - CF39 Series - LED monitor - curved - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/401461
Energy Class
Class E
Energy Consumption per Year
26 kWh
Power Consumption (On mode)
18 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (NTSC 1976)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
54.78 cm x 20.65 cm x 41.82 cm
3.3 kg
Display Type
Energy Class
Class E
26 kWh
Diagonal Size
24"
Viewable Size
23.5"
Curved Screen
Yes (1800R)
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
72% (NTSC 1976)
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode
54.78 cm x 20.65 cm x 41.82 cm - with stand
3.3 kg
VGA , HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-2/+22
VESA Mounting Interface
75 x 75 mm
1 x HDMI cable
Input Voltage
AC 120/230 V
18 W
18 kWh/1000h
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 54.78 cm - depth: 20.65 cm - height: 41.82 cm - weight: 3.3 kg , Without stand - width: 54.78 cm - depth: 8.76 cm - height: 32.63 cm - weight: 2.8 kg
Shipping Width
61.8 cm
Shipping Depth
16.6 cm
Shipping Height
39.4 cm
Shipping Weight
4.7 kg
10 °C
10 - 80% (non-condensing)
Brand: Samsung
