Samsung Samsung Adaptive Fast Charge TA Type C Cable
Quicklinx: CY2ZWS00 Mfr#: EP-TA20UBECGGB
It is made from durable and high-quality materials and to the strictest standards. This wall charger is almost compatible to all latest Samsung phones or other micro USB compatible smartphone. The Samsung 2 Amp charger recharges your phone’s battery at a much faster rate than your typical 1 Amp or 700mAh charger.
  • Rapid charging
    The Samsung wall charger plugs into any standard wall outlet via the AC adapter, and its compact design means it is small enough to throw in a briefcase or backpack when you're on the go. Samsung's charging technology powers your phone while it charges its battery, so you can make calls, check your messages or browse the web while your phone is charging.
  • Flexibility
    The Samsung wall charger also provides a detachable USB to micro-USB cable, which allows you to charge your phone from the USB port on your computer or other USB power source if you aren't near a wall outlet. You can also sync and transfer files between your computer and smartphone or other phone using the micro-USB cable. Keep one at home and one in your bag to make sure that your phone is always ready to go when you are.
Samsung Travel Adapter EP-TA20 power adapter - USB
Power adapter
Image Colour Disclaimer
The displayed product image may be a different colour
Output Connector Type
USB - on cable: USB-C
Voltage Provided
5 V
Max Electric Current
2 A
Fast Charge Technology
Samsung Adaptive Fast Charging
Cables
USB-C to USB-A cable - 1.5 m
Power adapter
Enclosure Colour
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
4 pin USB Type A
Detachable Cable Connector Type
USB-C
2 A
