Samsung S5 S34C500GAU - S50GC Series - LED monitor - 34" - 3440 x 14
Quicklinx: H8RCWS00 Mfr#: LS34C500GAUXXU
Diagonal Size: 34in
Max Resolution: 3440 x 1440
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, HDMI
Hurry, only 1 left in stock!
£291.66 ex VAT
£349.99 inc VAT
The Samsung ViewFinity S50C is a 34-inch WQHD monitor that combines an expansive display with stunning visuals, making it an excellent choice for both work and entertainment. With a high resolution of WQHD, this monitor delivers crisp and detailed images, providing a more immersive viewing experience. The S50C's sleek design and slim bezels enhance its modern aesthetic, while its ample screen real estate caters to multitasking needs. Whether you're engaged in professional tasks requiring precision or enjoying multimedia content, the Samsung ViewFinity S50C offers a spacious and visually impressive display for a wide range of applications.
21:9 Ultra WQHD
See more than before. Whether working on a project or enjoying a movie during downtime, see every detail on the wider display featuring a 21:9 aspect ratio. Ultra WQHD provides the simplest way to maximize screen real estate and experience truly seamless multitasking on just one screen
HDR10
Enjoy any content in stunning accuracy. With HDR10 that displays over 1 billion colors compared to 16.7 million for typical SDR technology, dark colors are darker and the brightest are brighter. Every piece of content becomes a joy to look at and can be experienced exactly as the creator intended
TUV-certified Intelligent Eye Care
Keep your eyes comfortable. An ambient light sensor on the monitor detects lighting in your workspace and automatically adjusts brightness. Excessive blue light is minimized with Eye Saver Mode while Flicker Free feature relieves eye strain.
100Hz Refresh rate
Smooth action with less lag and blur. A faster refresh rate updates the image on screen more often every second. The 100Hz refresh rate reduces lag and motion blur when playing games, watching videos, or working on design and video projects, delivering an ultra-smooth experience.
AMD FreeSync
Superfluid entertainment experience. AMD Radeon FreeSync keeps your monitor and graphics card refresh rate in sync to reduce image tearing. Watch movies and play games without interruptions. Even fast scenes look seamless and smooth.
Borderless Design
Minimal bezel brings maximum concentration. The virtually bezel-less screen shows you the full picture and looks almost gapless when used in a dual-monitor setup so you can see more at once with no distractions.
  • Do more on just one screen
    See more than before. Whether working on a project or enjoying a movie during downtime, see every detail on the wider display featuring a 21:9 aspect ratio. Ultra WQHD provides the simplest way to maximize screen real estate and experience truly seamless multitasking on just one screen.
  • Enjoy a billion colors with incredible depth
    Enjoy any content in stunning accuracy. With HDR10 that displays over 1 billion colors compared to 16.7 million for typical SDR technology, dark colors are darker and the brightest are brighter. Every piece of content becomes a joy to look at and can be experienced exactly as the creator intended.
  • Care for your eyes day or night
  • See any content smoother, even gaming
    Smooth action with less lag and blur. A faster refresh rate updates the image on screen more often every second. The 100 Hz refresh rate reduces lag and motion blur when playing games, watching videos, or working on design and video projects, delivering an ultra-smooth experience.
  • Stay in sync with the action
  • Expand your view, enhance your focus
Samsung ViewFinity S5 S34C500GAU - S50GC Series - LED monitor - 34" - HDR
LED-backlit LCD monitor - 34"
Energy Class
Class G
Energy Consumption per Year
47 kWh
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
UWQHD 3440 x 1440 at 100 Hz
Brightness
300 cd/m²
Contrast Ratio
3000:1
HDR Capable
HDR10
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1976)
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Voltage
AC 100-240 V
81.53 cm x 22.13 cm x 45.77 cm
4.9 kg
HDCP 2.2, TUV Rheinland Intelligent Eye Care Certification
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
47 kWh
Diagonal Size
34"
AMD FreeSync
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
3000:1
HDR Format
HDR10
Colour Support
Colour Gamut
72% NTSC (CIE 1976)
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture in picture, picture by picture, game mode, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, borderless, Adaptive Picture
81.53 cm x 22.13 cm x 45.77 cm - with stand
4.9 kg
DisplayPort 1.2 , 2 x HDMI (HDCP 2.2) , Headphones (mini-jack)
Mechanical
Tilt
Tilt Angle
-2/+22
VESA Mounting Interface
100 x 100 mm
HDMI cable
Input Voltage
AC 100-240 V
32 kWh/1000h
Power Consumption HDR (On mode)
50 kWh/1000h
Power Consumption (Typical)
32 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 81.53 cm - depth: 22.13 cm - height: 45.77 cm - weight: 4.9 kg , Without stand - width: 81.53 cm - depth: 3.64 cm - height: 35.98 cm - weight: 4.2 kg
Shipping Width
94.4 cm
Shipping Depth
15 cm
Shipping Height
43.4 cm
Shipping Weight
6.8 kg
10 °C
10 - 80% (non-condensing)
Diagonal Size: 34in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Brand: Samsung
