- Samsung S34J550WQR - LED monitor - 34.1"
- LED-backlit LCD monitor - 34.1"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/407873
- Energy Class
- Class F
- Energy Consumption per Year
- 41 kWh
- Power Consumption (On mode)
- 28 W
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- UWQHD 3440 x 1440 at 75 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, DisplayPort
- Tilt
- Voltage
- AC 120/230 V
- Dark grey/blue
- 82.81 cm x 24.28 cm x 47.08 cm
- 6.9 kg
- 2-year warranty
- Display Type
- Energy Class
- Class F
- 41 kWh
- Diagonal Size
- 34.1"
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- MagicBright, picture by picture, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, Low Input Lag, Picture-in-Picture
- Dark grey/blue
- 82.81 cm x 24.28 cm x 47.08 cm - with stand
- 6.9 kg
- DisplayPort 1.2 , 2 x HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -1.5/15
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 28 W
- Power Consumption SDR (On mode)
- 28 kWh/1000h
- Power Consumption (Typical)
- 28 Watt
- Power Consumption (Max)
- 59 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Included Software
- Easy Setting Box
- Dimensions & Weight Details
- With stand - width: 82.81 cm - depth: 24.28 cm - height: 47.08 cm - weight: 6.9 kg , Without stand - width: 82.81 cm - depth: 10.57 cm - height: 36.94 cm - weight: 6.4 kg
- Shipping Width
- 89.7 cm
- Shipping Depth
- 16.5 cm
- Shipping Height
- 43.9 cm
- Shipping Weight
- 9.5 kg
- Limited warranty - 2 years
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
