Samsung S34A650UXU 34" 3440x1440 5ms HDMI DP USB-C LED Monitor
Quicklinx: GBJ8WS00 Mfr#: LS34A650UXUXXU
Ultra-WQHD resolution with 34" curved display Immerse yourself in detail. Within games, movies or design projects, surround yourself with the 34" ultra-wide curved display featuring a 21:9 aspect ratio. Ultra-WQHD provides the simplest way to maximise your screen real estate and experience truly seamless multitasking on just one screen.
Enhanced concentration and comfort Enhance productivity and reduce eye strain for those long working days. 1000R curvature closely matches the curve of the human field of sight, allowing content to be viewed at a glance while proven to effectively limit eye strain compared with flat monitors for a more comfortable experience.
Enjoy a billion colours with incredible depth 1 billion colours with HDR 10 Enjoy any content in stunning colour accuracy and detail. With a wide range of colours, near limitless hues and HDR10, which makes dark colours darker and the brightest colours even brighter, every piece of content becomes a joy to look at and can be experienced exactly as the creator intended.
USB Type-C with LAN Port Ditch the clutter and keep connected. S6 features a USB Type-C port with 90W charging to power your laptop and transmit data with just one cable. It also has a LAN Port which allows a laptop that has no LAN port to simply connect to the monitor for Ethernet use.
Fast 100 Hz refresh rate The fast 100 Hz screen refresh rate provides smoother, silkier mouse sensitivity for enhanced productivity in any application. It also reduces screen stutter in fast-moving action scenes for a flawless gaming experience.
  • Enhanced concentration and comfort
    Boost productivity and reduce eye strain for those long working days. 1000R curvature closely matches the curve of the human field of sight, allowing content to be viewed at a glance while proven to effectively limit eye strain compared with flat monitors, for a more comfortable experience.
  • Amazing colors with HDR10
    Enjoy any content in stunning color accuracy and detail. With a wide range of colors, near limitless hues and HDR10, which makes dark colors dark and the brightest colors bright, every piece of content becomes a joy to look at and can be experienced exactly as the creator intended.
  • Keep your setup clean and clutter-free
    Ditch the clutter and keep connected. S6 features a USB Type-C port with 90W charging to power your laptop and transmit data with just one cable, in addition to a LAN Port which allows a laptop that has no LAN port to simply connect to the monitor for Ethernet use.
  • Advanced Eye Comfort
    Helps keep your eyes fresh for those late-night projects, as brightness and color temperature are adjusted automatically for optimization in many environments. TUV-certified for intelligent eye care, Samsung helps protect eyes against excessive blue light with eye saver mode and a flicker free feature.
  • Uninterrupted focus for optimum productivity
    With a virtually borderless design, stay focused on your work with minimum distractions. Or with dual-monitors, scan between multiple apps, emails or documents without breaking focus with near gapless continuity, complemented by the slim metal stand to meet any aesthetic needs.
  • Fast 100 Hz refresh rate
  • Stay in sync with the action
    Make your entertainment experience more fluid than ever. AMD FreeSync keeps your monitor and graphics card refresh rate in sync to reduce image tear and stutter. Movies and games have no interruptions and even fast action scenes are ultra-responsive and smooth.
Samsung S34A650UXU - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class G
Energy Consumption per Year
51 kWh
Power Consumption (On mode)
35 W
Curved Screen
USB 3.0/USB-C hub, Ethernet network adapter
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
UWQHD 3440 x 1440 at 100 Hz
Brightness
300 cd/m²
Contrast Ratio
4000:1
Response Time
5 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Voltage
AC 120/230 V
80.66 cm x 23.49 cm x 55.33 cm
7.6 kg
Environmental Standards
TCO Certified Displays 8, TCO Certified Displays 9
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
51 kWh
Diagonal Size
34"
Curved Screen
Yes (1000R)
Built-in Devices
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
4000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture by picture, game mode, Eco Light Sensor, Mega Infinity Dynamic Contrast Ratio, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, FreeSync Technology, Off Timer Plus, Picture-in-Picture, Adaptive Picture, Auto Source Switch
80.66 cm x 23.49 cm x 55.33 cm - with stand
7.6 kg
DisplayPort 1.2 , HDMI , Headphones , 3 x USB 3.0 , USB-C (power up to 90W) , Network
Mechanical
Tilt Angle
-2/+25
Swivel Angle
60
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x USB-C cable
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
35 W
35 kWh/1000h
Power Consumption HDR (On mode)
38 kWh/1000h
Power Consumption (Typical)
35 Watt
Dimensions & Weight Details
With stand - width: 80.66 cm - depth: 23.49 cm - height: 55.33 cm - weight: 7.6 kg , Without stand - width: 80.66 cm - depth: 12.81 cm - height: 36.94 cm - weight: 5.1 kg
Shipping Width
89.5 cm
Shipping Depth
21.6 cm
Shipping Height
47.1 cm
Shipping Weight
9.7 kg
Sustainability Information
TCO Certified
10 °C
10 - 80% (non-condensing)
