Samsung S32F351 32" 1920x1080 5ms HDMI VA LED Monitor
Quicklinx: D7D3WS00 Mfr#: LS32F351FUUXEN
Select:
  • 31.5"
Incredibly slim profile and stylish, contemporary design
  • Super slim panel: At an incredibly slim 10mm — as slender as a ballpoint pen — the one-piece panel is more than twice as thin as standard Samsung monitors.
  • Simple circular stand: A simple circular stand elegantly complements the super slim display.
  • Patterned rear panel and white finish: Horizontal patterning on the rear panel and white colour provide a stylish, contemporary finish.
Enhanced gaming experience with Game mode
  • Game mode instantly optimises screen colours and contrast for gaming to ensure you enjoy every scene at its best.
Optimised for viewing comfort
  • Eye Saver Mode: By reducing blue light emissions — which stimulate the retina more than other colour wavelengths — Eye Saver Mode reduces eye fatigue and provides a more comfortable viewing experience.
  • Flicker Free: Samsung’s Flicker Free technology minimises distracting screen flicker to let you work and play for longer in greater comfort.
Extra-wide viewing angle for the perfect view from anywhere
  • Extra-wide 178-degree viewing angle: An expanded 178-degree vertical and horizontal viewing angle ensures a clear picture from wherever you are watching.
  • Whether sitting back to relax or gathered around with friends, the wider viewing angle means everyone enjoys the perfect view from any position.
Samsung eco-saving technology reduces energy consumption and environmental impact
  • On Auto setting, Samsung’s eco-saving technology fluidly adjusts display brightness based on the luminescence of screen blacks to reduce energy consumption by up to 10%.
  • Screen brightness can also be set manually to 25% or 50% of maximum. * Based on internal testing.
  • Emotional from every angle
    The monitor is exceptionally slim. A minimalist round base exposes the display's elegant design, all accentuated by a stylized back panel.
  • Even better gameplay with Game Mode
    Game Mode instantly optimizes colors and contrast to give you even more gaming fun and an edge over your rivals.
  • Let your eyes rest
    From now on, work and entertainment will become much more enjoyable - even after many hours. Eye Saver mode reduces the emission of eye-straining blue light. In turn, Flicker Free technology protects your eyes by eliminating the screen flicker found in traditional monitors. Take care of your comfort and healthy eyesight.
  • Wide viewing angles
    The monitor's viewing angles are as wide as 178° - both vertically and horizontally. You can sit in front of it as comfortable as you like, without worrying about degradation of quality. Invite guests, too - everyone around you will see the image exactly as you do.
  • Technologies under the sign of Eco
    Automatically set screen brightness saves energy by adjusting it based on the black areas displayed on the screen. This helps reduce power consumption. You can also set the brightness level yourself - at 25%, 50% of maximum.
Samsung S32F351FUU - SF351 Series - LED monitor - Full HD (1080p) - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class A+
Energy Consumption per Year
42 kWh
Power Consumption (On mode)
29 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
5000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (NTSC 1976), 99% sRGB
Input Connectors
2xHDMI
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
High glossy white
73.16 cm x 24.77 cm x 52.22 cm
6.2 kg
Display Type
Energy Class
Class A+
42 kWh
Diagonal Size
32"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
5000:1
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eco Saving Plus, Eye Saver Mode, Super Slim Design, 99% sRGB colour gamut
High glossy white
73.16 cm x 24.77 cm x 52.22 cm - with stand
6.2 kg
2 x HDMI
Mechanical
Tilt
Tilt Angle
-1/+18
VESA Mounting Interface
75 x 75 mm
Input Voltage
AC 120/230 V
29 W
Power Consumption (Off Mode)
0.3 watt
Windows 10
Dimensions & Weight Details
With stand - width: 73.16 cm - depth: 24.77 cm - height: 52.22 cm - weight: 6.2 kg , Without stand - width: 73.16 cm - depth: 8.82 cm - height: 42.76 cm - weight: 5.4 kg
10 °C
10 - 80% (non-condensing)
