The ergonomics of the SD850 helps make your professional work space convenient and comfortable. Samsung's height adjustable stand (HAS) design lets you adjust the monitor height by up to 130mm. You can pivot, swivel, and tilt to adjust the perspective from horizontal to vertical. It even supports Auto OSD Rotation so you don't have to change the aspect ratios when you want to pivot your screen.
The SD850 features a bezel that helps provide a deeply immersive viewing experience that lets you concentrate on the tasks at hand.
View from various angles with the SD850. The Samsung LED Monitor has a wide viewing angle, vertically and horizontally.
With Picture-by-Picture (PBP), you can connect two compatible PCs to the same monitor and see the desktops of both simultaneously on one screen that's divided into two. Thanks to PBP and the WQHD resolution size you won't have to worry about losing the picture quality and resolution. Plug in your compatible laptop and your desktop and use both without needing to keep looking between different monitors - it's all there at a glance.
Samsung's latest Picture-in-Picture 2.0 technology lets you multi-task and watch videos. Whether it's 720p or 480p, PIP 2.0 doesn't downscale contents and helps maintain the same resolution as clear and crisp on its own. It supports resolutions up to HD and you can adjust the PIP resolution and position to help fit your needs.
The SD850's light sensor adjusts the screen brightness to help match your environment so that the screen is visible in a range of lighting conditions.
Business monitor
The panel provides more screen real estate, while high resolution provides more pixels, along with wide viewing angles. So you can enjoy greater viewing clarity, be more productive and maximize efficiency. -
Seamless multi-screen functionality
With split screen, you can connect two separate sources to the display and view them simultaneously.
- Samsung S32D850T - 8 Series - LED monitor - 32"
- LED-backlit LCD monitor - 32"
- Energy Class
- Class G
- Power Consumption (On mode)
- 56 W
- USB 3.0 hub
- Panel Type
- MVA
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Pixel Pitch
- 0.27675 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DVI-D, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Titanium silver, matte black
- 74.13 cm x 28 cm x 50 cm
- 12.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, TUV, C-Tick, EN55022, EN55024, CCC, PSB, AS/NZS 3548, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, VCCI V-3, KC, GB 9254-2008, GB 4943-2001 PSB, GB 17625.1-2003 EMC, KN22, KN24, K60950-1, IEC60950-1
- 3-year warranty
- Display Type
- Energy Class
- Class G
- Diagonal Size
- 32"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- MVA
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Pixel Pitch
- 0.27675 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Power off timer, MagicBright 3, game mode, Mega Dynamic Contrast Ratio, Eco Light Sensor, Eco Saving, Magic Upscale, auto-rotation, Mercury free, Image Size, PIP 2.0, PBP, USB Super-charging
- 74.13 cm x 28 cm x 50 cm - with stand
- 12.2 kg
- DVI-D (dual link) , HDMI , Headphones , DisplayPort , Audio line-in , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 60
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm, 200 x 200 mm
- Cables Included
- 1 x HDMI cable , 1 x DisplayPort cable , 1 x DVI cable , 1 x USB cable
- Power Supply
- Internal
- Input Voltage
- 56 W
- Power Consumption SDR (On mode)
- 56 kWh/1000h
- Power Consumption (Typical)
- 46 Watt
- Power Consumption Stand by
- 0.5 Watt
- OS Required
- Apple MacOS, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 74.13 cm - depth: 28 cm - height: 50 cm - weight: 12.2 kg , Without stand - width: 74.13 cm - depth: 6.85 cm - height: 44.1 cm - weight: 9.4 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
