Quad HD LED display
See more detail with the Samsung LS32A600UUUXXU Quad HD 32" LED Monitor. Its Quad HD display with HDR10 gives you rich contrast and vibrant colours, so everything on screen looks crisp and clear.
AMD FreeSync
Immerse yourself in your movies and games with AMD FreeSync. It matches the monitor refresh rate with your graphics card, so you get smooth, lag-free images. And with the wide viewing angles you can see everything clearly, even from the side or above.
Intelligent Eye Care
Stay comfortable while you work – the monitor's Eye-Saver mode protects your eyes during long sessions at the computer. It also uses flicker-free technology, so you can work or relax without any distracting screen flicker.
Display quality
The Samsung S32A600UUU features a 32-inch display with a native resolution of 2560 x 1440, providing clear and sharp images that bring content to life. -
Versatile connectivity options
Equipped with HDMI, DisplayPort, and USB-C interfaces, this monitor supports a range of devices for flexible connectivity and enhanced functionality. -
Enhanced comfort features
The monitor's Flicker-Free technology and Eye Saver Mode work together to minimize eye discomfort during long hours of use, making it ideal for extended viewing. -
Ergonomic design adjustments
With adjustable height, tilt, swivel, and pivot, the monitor's design promotes an ergonomic workspace that can adapt to various user needs. -
Color range
Supporting 1.07 billion colors, this monitor delivers rich and vibrant colors, enhancing the visual experience across different types of content.
- Samsung S32A600UUU - LED monitor - QHD - 32" - HDR
- LED-backlit LCD monitor - 32"
- Energy Class
- Class G
- Energy Consumption per Year
- 51 kWh
- Power Consumption (On mode)
- 37 W
- USB 3.0/USB-C hub, Ethernet network adapter
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 75 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- HDR Capable
- HDR10
- Response Time
- 5 ms
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Black
- 71.62 cm x 21.14 cm x 58.05 cm
- 7.2 kg
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- 51 kWh
- Diagonal Size
- 32"
- Built-in Devices
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- HDR Format
- HDR10
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Picture by picture, game mode, Mega Dynamic Contrast Ratio, Eco Light Sensor, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, FreeSync Technology, Off Timer Plus, Picture-in-Picture, Adaptive Picture, Auto Source Switch
- Black
- 71.62 cm x 21.14 cm x 58.05 cm - with stand
- 7.2 kg
- DisplayPort 1.2 , DisplayPort 1.2 output , HDMI , Headphones , 3 x USB 3.0 , USB-C (power up to 90W) , Network
Mechanical
- Tilt Angle
- -2/+25
- Swivel Angle
- 60
- Rotation Angle
- -2/+92
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable , 1 x USB-C cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 37 W
- Power Consumption SDR (On mode)
- 37 kWh/1000h
- Power Consumption HDR (On mode)
- 50 kWh/1000h
- Power Consumption (Typical)
- 37 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 71.62 cm - depth: 21.14 cm - height: 58.05 cm - weight: 7.2 kg , Without stand - width: 71.62 cm - depth: 4.13 cm - height: 42.47 cm - weight: 5 kg
- Shipping Width
- 80 cm
- Shipping Depth
- 17.1 cm
- Shipping Height
- 51.1 cm
- Shipping Weight
- 9.2 kg
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
