Samsung S29E790C 29" 2560x1080 4ms HDMI DisplayPort Curved LED Monitor
ULTRA-WIDE SCREEN FOR MULTI-TASKING!
Quicklinx: B8M7WS00 Mfr#: LS29E790CNS/EN
With the latest innovations in technology, monitors have evolved to feature stunning curved screens that match the natural curvature of the human eye, providing a more uniform and comfortable viewing experience. With a best-in-class curvature and an ultra-wide 21:9 aspect ratio, the Samsung Curved Monitor SE790C delivers unrivaled comfort and truly immersive viewing.
  • Experience vibrant picture quality with Ultra WQHD and a best-in-class contrast ratio
    The SE790C has what it takes to provide truly vibrant picture quality and comfortable enhanced viewing from any angle, optimized for your efficient working needs.
  • A superlative ergonomic design that also delivers on comfort and convenience
    With thoughtful design and engineering, the SE790C is much more than a monitor with stunning looks. It features everything from an adjustable stand to VESA mounting support and a wide range of connectivity options.
  • Ultra-wide screen with ultra-capable multitasking
    Manage all your windows on one ultra-wide panoramic display. Whether it's two windows side-by-side or a picture within a picture, boost your productivity with best-in-class multitasking features and outstanding picture quality.
  • Take your entertainment to new heights of immersion and comfort
    The SE790C comes with useful advanced features that optimize your picture and sound to give you a richly immersive and realistic entertainment experience.
  • Give comfort to your eyes with Flicker Free
    Flicker Free technology protects your eyes from the constant strain caused by flickering screens on conventional monitors so you can work and enjoy reading, playing games, watching movies, and editing photos for longer without eye fatigue. Have a more pleasing immersive visual experience with Flicker Free.
  • Game mode
    Instantly adjust your monitor settings for an optimized gaming experience through the on-screen display.
  • Ultra WQHD
    A step up from WQHD and 2.5 times the pixel density of Full HD, Ultra WQHD's advanced 3440 x 1440 resolution provides an unmatched visual experience that lets you see more details at a glance, but with the added benefit of a wider resolution so you can view content on a wider scale.
  • Best-in-class 3,000:1 static contrast ratio
    More vivid than conventional monitors to provide truly lifelike pictures with deeper blacks, pristine whites, and amazingly bright colors, with hardly and light leakage.
  • Wide viewing angle
    Delivers a 178° wide viewing angle horizontally and vertically for optimal viewing experience from any angle.
  • Ultra-wide 21:9 aspect ratio
    Get up-close and personal with the ultimate panoramic theater experience, or split the screen into multiple spaces for unparalleled efficiency.
Samsung S29E790C - SE790C Series - LED monitor - curved - 29"
LED-backlit LCD monitor - 29"
Energy Class
Class B
Energy Consumption per Year
61 kWh
Power Consumption (On mode)
42 W
Curved Screen
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Full HD 2560 x 1080 at 60 Hz
Pixel Pitch
0.2628 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort
Speakers
Internal
Display Position Adjustments
Height, tilt
Voltage
Black, metallic silver
69.95 cm x 6.85 cm x 31.35 cm
4.7 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
61 kWh
Diagonal Size
29"
Curved Screen
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.2628 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, power off timer, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Flicker Free technology, Ultra-Flexible Height Adjustment System (HAS), side-by-side, Image Size, PIP 2.0, PBP
69.95 cm x 6.85 cm x 31.35 cm - without stand
4.7 kg
Audio
Speakers - stereo - internal
Output Power / Channel
7 Watt
DisplayPort , 2 x HDMI , Headphones
Mechanical
Height, tilt
Tilt Angle
-2/+20
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x Mini DisplayPort-DisplayPort adapter
Power Supply
External
Input Voltage
42 W
Power Consumption (Typical)
30.6 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Without stand - width: 69.95 cm - depth: 6.85 cm - height: 31.35 cm - weight: 4.7 kg , With stand - width: 69.95 cm - depth: 26.26 cm - height: 42.37 cm - weight: 7.2 kg
Sustainability Information
ENERGY STAR Certified
