Samsung S27R650FDU 27" 1920x1080 5ms HDMI DP LED Monitor
Quicklinx: GBJQWS00 Mfr#: LS27R650FDUXXU
So many ways to connect with HDMI, Display port, VGA and USB. A full line up for ports brings you the complete connectivity you need in today's working environment.
Protected eyes stay focused through the whole shift. Advanced eye comfort technology reduces eye strain for heightened concentration and greater productivity. Flicker Free technology continuously removes tiring and irritating screen flicker, while Eye Saver Mode minimizes blue light emissions.
The height-adjustable monitor swivels, tilts, and pivots for you to see your work any way you want. The sleek and clean design adds a touch of style to your office interior and is VESA-compatible for easy installation
Smart Eco Saving technology achieves power-consumption reductions of up to 10% while still maintaining picture quality. It adjusts the brightness of the screen's black sections while simultaneously adjusting the RGB gain values, so the screen looks just as bright as you remember.
The IPS panel preserves colour vividness and clarity across every inch of the screen. Work comfortably on the productivity-boosting wide display and see accurate tones and shades from 178° all around, with no colour washing
  • Enhanced connectivity
    Equipped with HDMI, VGA, and DisplayPort interfaces, this monitor offers versatile connectivity options for seamless integration into any workspace.
  • Optimal viewing comfort
    Featuring Eye Saver Mode and Flicker-Free technology, the monitor reduces eye strain during long working hours, ensuring a comfortable viewing experience.
  • Adjustable design
    With height, pivot, swivel, and tilt adjustments, users can easily find their optimal viewing position, enhancing productivity and comfort.
  • Superior image quality
    The 27-inch display with Full HD resolution, 16.7 million colors, and Mega Dynamic Contrast Ratio delivers vivid and sharp visuals for an immersive viewing experience.
  • Efficient performance
    AMD FreeSync technology and a 75 Hz refresh rate provide smooth and efficient performance, reducing lag and motion blur for a competitive edge in gaming and video playback.
Samsung S27R650FDU - SR65 Series - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/360400
Energy Class
Class F
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Adaptive-Sync Technology
AMD FreeSync
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
Dark grey/blue
61.23 cm x 23.8 cm x 53.9 cm
6.4 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class F
35 kWh
Diagonal Size
27"
AMD FreeSync
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus
Dark grey/blue
61.23 cm x 23.8 cm x 53.9 cm - with stand
6.4 kg
VGA , DisplayPort 1.2 , HDMI , Audio line-in , Headphones , 2 x USB 3.0 , 2 x USB 2.0
Mechanical
Tilt Angle
-5/+24
Swivel Angle
90
Rotation Angle
-2/+92
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
24 W
24 kWh/1000h
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.4 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.23 cm - depth: 23.8 cm - height: 53.9 cm - weight: 6.4 kg , Without stand - width: 61.23 cm - depth: 7.62 cm - height: 36.16 cm - weight: 4.2 kg
Shipping Width
68.5 cm
Shipping Depth
21.5 cm
Shipping Height
43.5 cm
Shipping Weight
8.6 kg
Sustainability Information
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
