Samsung S27H650FDU 27" 1920x1080 5ms VGA HDMI DP PLS LED Monitor
Quicklinx: D7DHWS00 Mfr#: LS27H650FDUXEN
Select:
  • 27"
The SH65 series is a just-right fit for any professional work environment, with its advanced PLS panel where texts are thoroughly vivid and images crystal clear, without color shift, from whichever angle they are looked at.
  • Long-lasting eye comfort
    The eye saver mode reduces blue light emissions, which are known to cause damage to the retina, and in turn helps you minimize eye strain when working long hours, thus keeping your productivity afloat.
  • Ergonomic design
    It swivels, tilts, pivots, and is height adjustable, ready to meet the needs of any usage scenario. Its sleek yet sturdy build, coupled with clean back design, blends in perfectly with any office or personal space.
  • Multiple connectivity
    The SH65 series provides multi connectivity with DP, HDMI and USB ports on the back of the monitor, prepared to be connected with whatever devices your team or your client chooses to connect for better business outcomes.
Samsung S27H650FDU - SH65 Series - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25 W
USB Hub
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
62.98 cm x 23.6 cm x 54.96 cm
6.9 kg
Display Type
Energy Class
Class F
37 kWh
Diagonal Size
27"
Built-in Devices
USB Hub
Panel Type
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Image Size, Smart Eco Saving, Off Timer Plus
62.98 cm x 23.6 cm x 54.96 cm - with stand
6.9 kg
HDMI , VGA , DisplayPort , USB
Mechanical
Tilt Angle
-5/+24
Swivel Angle
90
Rotation Angle
-2/+92
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
Input Voltage
AC 120/230 V
25 W
25 kWh/1000h
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.005 Watt
Dimensions & Weight Details
With stand - width: 62.98 cm - depth: 23.6 cm - height: 54.96 cm - weight: 6.9 kg , Without stand - width: 62.98 cm - depth: 7.68 cm - height: 37.1 cm - weight: 4.7 kg
10 °C
10 - 80% (non-condensing)
