With thoughtful design and engineering, the SE510C is much more than a monitor with stunning looks. Featuring a glossy black body that is framed perfectly by a narrow bezel and elevated by a T-shaped stand, it's carefully designed to keep the focus on your content viewing pleasure.
- Samsung S27E510C - SE510C Series - LED monitor - curved - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 54 kWh
- Power Consumption (On mode)
- 37 W
- Curved Screen
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.3114 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Shiny black
- 62.32 cm x 18.16 cm x 46.3 cm
- 5.52 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Energy Class
- Class B
- 54 kWh
- Diagonal Size
- 27"
- Curved Screen
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3114 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode
- Shiny black
- 62.32 cm x 18.16 cm x 46.3 cm - with stand
- 5.52 kg
- VGA , HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -2/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Power Supply
- External
- Input Voltage
- AC 120/230 V
- 37 W
- Power Consumption (Typical)
- 28 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- OS Required
- Apple MacOS, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 62.32 cm - depth: 18.16 cm - height: 46.3 cm - weight: 5.52 kg , Without stand - width: 62.32 cm - depth: 5.99 cm - height: 36.57 cm - weight: 4.91 kg
Sustainability Information
- ENERGY STAR Certified
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
