Instantly optimizing screen colors and contrast for gaming, Game Mode ensures you get to see game scenes at their best. Eye Saver Mode optimizes your viewing comfort by smartly reducing blue light emissions at the touch of a button. Flicker Free technology reduces screen flickering for a more comfortable viewing experience.
Eco-saving technology reduces screen brightness for increased energy efficiency. In addition to the two standard manual settings (Minimum at 25% and Maximum at 50%), there is now a brand new Auto Setting that reduces energy up about 10%, based on the luminescence of the screen's black sections. The screen brightness transitions fluidly while simultaneously saving energy. Monitor mechanisms and circuits are constructed without PVC making for an eco-friendly device, lessening environmental impact.
Experience darker blacks with Game Mode
Instantly optimizing screen colors and contrast for gaming, Game Mode ensures you get to see game scenes at their best. -
Easy on the eyes for a more comfortable viewing experience
Eye Saver Mode optimizes your viewing comfort by smartly reducing blue light emissions at the touch of a button. Flicker Free technology reduces screen flickering for a more comfortable viewing experience. -
Save energy and the environment with this eco-friendly monitor
Eco-saving technology reduces screen brightness for increased energy efficiency. In addition to the two standard manual settings (Minimum at 25% and Maximum at 50%), there is now a brand Auto Setting that reduces energy up about 10%, based on the luminescence of the screen's black sections. The screen brightness transitions fluidly while simultaneously saving energy. Monitor mechanisms and circuits are constructed without PVC making for an eco-friendly device, lessening environmental impact.
- Samsung S27E330H - SE310 Series - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/362948
- Energy Class
- Class G
- Energy Consumption per Year
- 48 kWh
- Power Consumption (On mode)
- 33 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (NTSC 1976)
- Input Connectors
- HDMI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Black
- 64.34 cm x 20.07 cm x 46.31 cm
- 5.1 kg
- Display Type
- Energy Class
- Class G
- 48 kWh
- Diagonal Size
- 27"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72% (NTSC 1976)
- Response Time
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- MagicBright, MagicAngle, game mode, Mega Infinity Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode
- Black
- 64.34 cm x 20.07 cm x 46.31 cm - with stand
- 5.1 kg
- VGA , HDMI
Mechanical
- Tilt
- Tilt Angle
- -1/+20
- VESA Mounting Interface
- 75 x 75 mm
- Cables Included
- 1 x HDMI cable
- Input Voltage
- AC 120/230 V
- 33 W
- Power Consumption SDR (On mode)
- 33 kWh/1000h
- Power Consumption (Typical)
- 35 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- OS Required
- Windows 10
- Dimensions & Weight Details
- With stand - width: 64.34 cm - depth: 20.07 cm - height: 46.31 cm - weight: 5.1 kg , Without stand - width: 64.34 cm - depth: 9.51 cm - height: 38.53 cm - weight: 4.7 kg
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
