The SD850 has 2560 x 1440 wide quad high-definition (WQHD) resolution, twice that of Full HD, with a 178° viewing angle. The monitor can display over one billion colors, incorporating 100 per cent of the sRGB color space. Its approximate 3.7 million pixels offer deep and rich image detail for a more realistic picture. Aimed at content creaters, programmers and those in financial services, the monitor can not only display picture-in-picture in 720p, but also picture-by-picture to display images from two separate sources, such as a laptop and a desktop PC.
The SD850 has an eco light sensor that adapts the brightness of the monitor dynamically according to available light to save power. The monitor also has an Energy Star rating of 6.0 to ensure efficiency. The materials that make up the SD850 have also been TCO Certified.
WQHD 2560 x 1440 resolution
At nearly twice the resolution of a standard monitor, the 27" S27D850T allows you to see more, more clearly. With more resolution, smaller fonts are legible, and details in photos, videos and illustrations are more discernible. -
100% sRGB color compliance
For those professionals who depend on accurate color, the S27D850T is 100% sRGB compliant. From conception to output, your color will be exactly the color you specify. Plus, with a 178-degree wide viewing panel, the image is clearly viewable at off angles. -
Split screen and picture in picture
Twice the resolution allows twice the screen information. With split screen and PIP, you can view two distinct video inputs simultaneously. Code in one window and see the results in the other. Compare your photo or document revisions with the original while you work. Read your email in one screen while editing a document in the other. -
Ergonomic and slim bezel design
The SD850 series monitors deliver not only great image performance, but also enhanced ergonomics and a beautiful, beveled slim-bezel design that looks great, on or off. Enhance your productivity and your desk with the Samsung SD850 series monitor.
- Samsung S27D850T - SD850 Series - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class C
- Energy Consumption per Year
- 67 kWh
- Power Consumption (On mode)
- 46 W
- USB 3.0 hub
- Panel Type
- Plane to Line Switching (PLS)
- Native Resolution
- 2560 x 1440
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 1 billion colours
- Input Connectors
- HDMI, DVI-D, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Titanium silver, matte black
- 62.74 cm x 28 cm x 59.63 cm
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 67 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- Native Resolution
- 2560 x 1440
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- 1 billion colours
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Power off timer, MagicBright 3, game mode, Eco Light Sensor, Eco Saving, Magic Upscale, auto-rotation, PIP 2.0, PBP, USB Super-charging
- 62.74 cm x 28 cm x 59.63 cm - with stand
- DVI-D (dual link) , HDMI , USB 3.0 , DisplayPort
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 60
- Height Adjustment
- 130 mm
- Cables Included
- 1 x USB cable
- TUV GS
- Power Supply
- Internal
- 46 W
- Power Consumption Stand by
- 0.45 Watt
- OS Required
- Apple MacOS, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 62.74 cm - depth: 28 cm - height: 59.63 cm , Without stand - width: 62.74 cm - depth: 6.61 cm - height: 37.64 cm - weight: 7.1 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
