The Samsung S27D400GAU is a versatile 27-inch desktop monitor designed to enhance your viewing experience with impressive Full HD (1080p) resolution. It features a dynamic image with a brightness of 250 cd/m2 and a contrast ratio of 1000:1, ensuring vivid and clear visuals whether for work or play. With a response time of 5 ms and a V-Sync rate of 100 Hz, fast-moving images play smoothly, making it ideal for gaming and multimedia applications. The monitor also boasts an expansive 178-degree horizontal and vertical viewing angle, providing consistent color and clarity from various positions. This monitor comes equipped with a range of convenient features, including a USB 2.0 hub for easy device connectivity and multiple adjustment options such as tilt, height, and swivel to ensure ergonomic comfort. The Slim Design and Flicker-Free technology contribute to a modern aesthetic while reducing eye strain during extended use. With an energy-efficient profile, including Energy Saver mode and an eco-friendly design featuring 16.3% recycled plastic, the Samsung S27D400GAU delivers performance while being mindful of the environment.
- Samsung S27D400GAU - S40GD Series - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/2109447
- Energy Class
- Class C
- Energy Consumption per Year
- 20 kWh
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 100 Hz
- Pixel Pitch
- 0.3113 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931)
- Input Connectors
- 2xHDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 100-240 V
- Black
- 61.27 cm x 21.9 cm x 53.83 cm
- 4 kg
- Environmental Standards
- TCO Certified, generation 10, for displays
- HDCP 1.2
- Display Type
- Energy Class
- Class C
- 20 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3113 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72% (CIE 1931)
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, Energy Saver, Image Size, Eye Saver Mode, Off Timer Plus, Super Slim Design, Auto Source Switch
- Black
- 61.27 cm x 21.9 cm x 53.83 cm - with stand
- 4 kg
- 2 x HDMI , DisplayPort 1.2 (HDCP 1.2) , Headphone jack (mini-jack) , 2 x USB 2.0 downstream , USB 2.0 upstream (Type B)
Mechanical
- Tilt Angle
- -3/+25
- Swivel Angle
- 90
- Rotation Angle
- 184
- Height Adjustment
- 105 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), 16.3% recycled plastic
- Cables Included
- 1 x HDMI cable
- HDCP 1.2
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 100-240 V
- Power Consumption SDR (On mode)
- 14 kWh/1000h
- Power Consumption (Typical)
- 14 Watt
- Power Consumption (Max)
- 50 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 61.27 cm - depth: 21.9 cm - height: 53.83 cm - weight: 4 kg , Without stand - width: 61.27 cm - depth: 3.98 cm - height: 36.09 cm - weight: 2.7 kg
- Shipping Width
- 65.5 cm
- Shipping Depth
- 48.8 cm
- Shipping Height
- 10.9 cm
- Shipping Weight
- 5.6 kg
Sustainability Information
- TCO Certified
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
