Matching a slim and stylish design with unbelievable 3D depth and clarity is one sure way of grabbing attention. And that's exactly what the Samsung 3D LED Monitor SA950 achieves. It delivers unbelievably smooth visuals through its 3D HyperReal Engine and the Real 120Hz speed, while also producing brighter 3D images. Other features include the Mega Dynamic Contrast Ratio and Photo Accuracy 100%, which really bring pictures to life. While the built-in 3D Converter and various inputs ensure that your monitor experience is truly expansive. Then factor in the eco saving modes with the new Energy Tree feature, and you have a next-generation monitor ready to go.
Catch every detail with Real 120Hz
Samsung 3D LED Monitor SA950 is ready to redefine your whole world of entertainment through its enhanced Real 120Hz picture clarity. Pictures will surprise you with their crystal-clear sharpness and smoothness. Whether it is 2D or 3D, action packed scenes or intimate close-ups will be so true-to-life that you will mistake them for reality. The Real 120Hz ensures that images are not lost and sequences are super smoother. This makes for a more comfortable and enjoyable experience. And when you factor in the amazing brightness, this 3D experience will have you totally mesmerised. -
Gentle on the eyes and on the environment
Save electricity and hassle with Samsung's Eco light sensor. By adjusting screen brightness to match your surrounding environment, the SA950's Eco light sensor creates a brilliant visual display while also minimising your energy consumption. You will benefit from a more comfortable viewing experience that is far better for the environment. Monitor brightness is adjusted to match your ambient light, which ensures that the screen is highly visible and appropriately set for your eyes. So, in a dark room the screen will reduce brightness, but when sitting in a room with plenty of light, it will increase brightness. The Eco light sensor is simply perfect for modern living - helping you conserve energy and keep comfortable. -
Save energy with new smart motion technology
Step into the future with the 3D LED monitor SA950 monitor, which utilises the very latest in motion sensors to create a monitor that hangs on your every movement. With a built-in PIR (Pyrolectric Infrared Ray) sensor, the SA950 automatically detects movement within a specified area in front of the screen. This allows your monitor to automatically dim or power off, and then power back on or brighten once detecting a nearby viewer. This Eco motion sensor is the easiest way to conserve energy. -
See true colours with Photo Accuracy 100%
Nothing beats true-to-life clarity and colour. Samsung Photo Accuracy 100% ensures that your captured moments, whether on digital camera or camcorder, are represented exactly as you remember them. The Photo Accuracy distinguished itself with its sRGB colour, which is the standard colour of digital devices, such as monitors, digital cameras and scanner, and brings your captured moments to life without the annoying distortions. Samsung 3D LED monitor SA950 screen reproduces colour for crystal clear, realistic images and is the perfect way to relive precious memories. -
See 2D in a new dimension with a 3D converter
Enjoying 2D images in 3D may seem like a fantasy, but with Samsung it is a brilliant reality. At the push of a button Samsung 3D Converter transforms your favourite TV programmes or movies with amazing 3D-depth. It will reinvent your favourite 2D content. And with the 3D visual adjustment feature, you can even customise your 3D experience to match your particular likes. It is a new level of visual comfort.
- Diagonal Size
- 27 in
- Max Resolution
- 1920 x 1080
- Response Time
- 2 ms
- HDMI
- Silver
- Dimensions & Weight / Depth
- 18.6 cm
- Dimensions & Weight / Height
- 47.4 cm
- Dimensions & Weight / Width
- 62.1 cm
- Display (Projector) / Image Brightness
- 300 cd/m2
- Display (Projector) / Image Contrast Ratio
- 1000:1
- Header / Product Line
- Samsung SyncMaster
- Technology
- TFT active matrix
