Quad HD LED display
See more detail with the Samsung LS27A600UUUXXU Quad HD 27" LED Monitor. Its Quad HD display with HDR10 gives you rich contrast and vibrant colours, so everything on screen looks crisp and clear.
AMD FreeSync
Immerse yourself in your movies and games with AMD FreeSync. It matches the monitor refresh rate with your graphics card, so you get smooth, lag-free images. And with the wide viewing angles you can see everything clearly, even from the side or above.
Intelligent Eye Care
Stay comfortable while you work – the monitor's Eye-Saver mode protects your eyes during long sessions at the computer. It also uses flicker-free technology, so you can work or relax without any distracting screen flicker.
Discover the details
Experience details not seen before. When watching your favorite movie or working on your latest project, benefit from levels of precision up to 1.7x the pixel density of Full HD. QHD provides more room for multitasking or taking in beautiful videos and images. -
See greatness from any angle
Optimized for professional work environments, Samsung high-resolution monitors feature an IPS panel delivering crystal clear color quality and a wide viewing angle of 178°. Every user can expect a great viewing experience from any angle in vivid and vibrant color without washing or fade. -
Enjoy a billion colors with incredible depth
Enjoy any content in stunning color accuracy and detail. With a wide range of colors, near limitless hues and HDR10, which makes dark colors darker and the brightest colors even brighter, every piece of content becomes a joy to look at and can be experienced exactly as the creator intended. -
Work clutter-free and stress-free
Ditch the clutter and enjoy simplicity. Samsung high-resolution monitors features a USB type-C port to power your laptop and transmit data with just one cable. With multiple USB 3.0 ports, you can also plug devices directly into the monitor for a clearer, cleaner workspace. -
Relieve your eyes from strain
Keep your eyes fresh and strain-free. For those late-night projects, brightness and color temperature adjust automatically for optimization in any environment. With TUV-certified eye care technology, Samsung protects eyes against excessive blue light with eye saver mode and a Flicker Free feature. -
Maximize comfort, minimize distractions
Position your monitor for optimal comfort. Borderless design, VESA mount compatibility and a variety of tilt, swivel and pivot control points allow you to mount your monitor in any environment. In addition, a slim metal stand and narrow depth take up less desk space for a clean, seamless work setup. -
Stay in sync with the action
Make your entertainment experience more fluid than ever. AMD FreeSync keeps your monitor and graphics card refresh rate in sync to reduced image tear and stutter. Movies and games have no interruptions and even fast action scenes are ultra-responsive and smooth. -
Create a sustainable future
Transform your Eco-friendly FSC-certified packaging into practical tools or choose to recycle for enhanced sustainability. Globally certified for energy efficiency, Samsung monitor features Eco saving plus mode that preserves up to 10% more energy, while maintaining bright and vivid picture quality. -
Plug and see
No more switching around. With automatic source switch plus, your monitor detects newly connected devices as soon they're plugged in, and displays the correct signal. No more searching for the right input on the menu.
 - Samsung S27A600UUU - S60UA Series - LED monitor - QHD - 27" - HDR
 - LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/458922
- Energy Class
 - Class E
- Power Consumption (On mode)
 - 21 W
- Adaptive-Sync Technology
 - AMD FreeSync
- Daisy Chaining
 - USB 3.0/USB-C hub, USB PD 90 Watt
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - QHD 2560 x 1440 at 75 Hz
- Brightness
 - 300 cd/m²
- Contrast Ratio
 - 1000:1
- HDR Capable
 - HDR10
- Response Time
 - 5 ms
- Colour Support
 - 1.07 billion colours
- Input Connectors
 - HDMI, DisplayPort, USB-C
 - Height, pivot (rotation), swivel, tilt
- Voltage
 - AC 120/230 V
 - Black
 - 61.55 cm x 19.64 cm x 55.19 cm
 - 6.7 kg
- Environmental Standards
 - TCO Certified Displays 9, ENERGY STAR Qualified
 - TUV
- Display Type
- Energy Class
 - Class E
- Energy Class (HDR)
 - Class G
- Diagonal Size
 - 27"
 - AMD FreeSync
- Daisy Chaining
- Built-in Devices
 - USB 3.0/USB-C hub
- USB Power Delivery
 - 90 Watt
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Brightness
 - 300 cd/m²
- Contrast Ratio
 - 1000:1
- HDR Format
 - HDR10
- Colour Support
- Response Time
 - 5 ms
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Backlight Technology
 - LED backlight
 - Picture by picture, game mode, Mega Dynamic Contrast Ratio, Eco Light Sensor, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, Picture-in-Picture, Adaptive Picture, Auto Source Switch
 - Black
 - 61.55 cm x 19.64 cm x 55.19 cm - with stand
 - 6.7 kg
 - DisplayPort 1.2 , DisplayPort 1.2 output , HDMI , Headphones , 3 x USB 3.0 , USB-C (power up to 90W) , Network
Mechanical
- Tilt Angle
 - -2/+25
- Swivel Angle
 - 60
- Rotation Angle
 - -2/+92
- Height Adjustment
 - 120 mm
- VESA Mounting Interface
 - 100 x 100 mm
- Cables Included
 - 1 x HDMI cable , 1 x USB-C cable
 - TUV
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - AC 120/230 V
 - 21 W
- Power Consumption SDR (On mode)
 - 21 kWh/1000h
- Power Consumption HDR (On mode)
 - 32 kWh/1000h
- Power Consumption (Typical)
 - 21 Watt
- Power Consumption Stand by
 - 0.5 Watt
 - 0.3 Watt
- Dimensions & Weight Details
 - With stand - width: 61.55 cm - depth: 19.64 cm - height: 55.19 cm - weight: 6.7 kg , Without stand - width: 61.55 cm - depth: 4.27 cm - height: 36.82 cm - weight: 4.7 kg
- Shipping Width
 - 68.6 cm
- Shipping Depth
 - 17.1 cm
- Shipping Height
 - 45 cm
- Shipping Weight
 - 8.4 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
 - 10 °C
 - 40 °C
 - 10 - 80% (non-condensing)
