Quad HD LED display
See more detail with the Samsung LS27A600NWUXXU Quad HD 27" LED Monitor. Its Quad HD display with HDR10 gives you rich contrast and vibrant colours, so everything on screen looks crisp and clear.
AMD FreeSync
Immerse yourself in your movies and games with AMD FreeSync. It matches the monitor refresh rate with your graphics card, so you get smooth, lag-free images. And with the wide viewing angles you can see everything clearly, even from the side or above.
Intelligent Eye Care
Stay comfortable while you work - the monitor's Eye-Saver mode protects your eyes during long sessions at the computer. It also uses flicker-free technology, so you can work or relax without any distracting screen flicker.
 - Samsung S27A600NWU - S60A Series - LED monitor - QHD - 27" - HDR
 - LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/458919
- Energy Class
 - Class E
- Power Consumption (On mode)
 - 21 W
- Adaptive-Sync Technology
 - AMD FreeSync
 - USB 3.0 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - QHD 2560 x 1440 at 75 Hz
- Brightness
 - 300 cd/m²
- Contrast Ratio
 - 1000:1
- HDR Capable
 - HDR10
- Response Time
 - 5 ms
- Colour Support
 - 1.07 billion colours
- Input Connectors
 - HDMI, DisplayPort
 - Height, pivot (rotation), swivel, tilt
- Voltage
 - AC 120/230 V
 - Black
 - 61.55 cm x 19.64 cm x 55.19 cm
 - 6.4 kg
- Environmental Standards
 - TCO Certified Displays 9, ENERGY STAR Qualified
 - TUV
- Display Type
- Energy Class
 - Class E
- Energy Class (HDR)
 - Class G
- Diagonal Size
 - 27"
 - AMD FreeSync
- Built-in Devices
 - USB 3.0 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Brightness
 - 300 cd/m²
- Contrast Ratio
 - 1000:1
- HDR Format
 - HDR10
- Colour Support
- Response Time
 - 5 ms
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Backlight Technology
 - LED backlight
 - Picture by picture, game mode, Mega Dynamic Contrast Ratio, Eco Light Sensor, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, Picture-in-Picture, Adaptive Picture, Auto Source Switch
 - Black
 - 61.55 cm x 19.64 cm x 55.19 cm - with stand
 - 6.4 kg
 - DisplayPort 1.2 , HDMI , Headphones , 3 x USB 3.0 , USB 2.0
Mechanical
- Tilt Angle
 - -2/+25
- Swivel Angle
 - 60
- Rotation Angle
 - -2/+92
- Height Adjustment
 - 120 mm
- VESA Mounting Interface
 - 100 x 100 mm
- Cables Included
 - 1 x HDMI cable , 1 x SuperSpeed USB cable
 - TUV
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - AC 120/230 V
 - 21 W
- Power Consumption SDR (On mode)
 - 21 kWh/1000h
- Power Consumption HDR (On mode)
 - 32 kWh/1000h
- Power Consumption (Typical)
 - 21 Watt
- Power Consumption Stand by
 - 0.5 Watt
 - 0.3 Watt
- Dimensions & Weight Details
 - With stand - width: 61.55 cm - depth: 19.64 cm - height: 55.19 cm - weight: 6.4 kg , Without stand - width: 61.55 cm - depth: 4.27 cm - height: 36.82 cm - weight: 4.4 kg
- Shipping Width
 - 68.6 cm
- Shipping Depth
 - 17.1 cm
- Shipping Height
 - 45 cm
- Shipping Weight
 - 8.1 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
 - 10 °C
 - 40 °C
 - 10 - 80% (non-condensing)
