Samsung S24R650FDU 24" 1920x1080 5ms HDMI DP LED Monitor
Quicklinx: GBJPWS00 Mfr#: LS24R650FDUXXU
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15), HDMI, DisplayPort
£179.16 ex VAT
£214.99 inc VAT
Focus on a full screen
A minimal bezel brings maximum concentration. The virtually borderless screen shows you the full picture and looks almost gapless when used in a dual-monitor setup. See more at once with no distractions in your way, and get through larger sections of your to-do list during screen time.
True colour preservation
Perfect colour down to the last detail. The IPS panel preserves vividness and clarity across every inch of the screen. Work comfortably on the productivity-boosting wide display. From 178¢ª all around, tones and shades look accurate and without colour washing.
Ready to connect
More ports and peripherals for multiple possibilities. Connect to virtually any device with the triple HDMI, DP and DVI interface. Built-in speakers bring on-demand listening. There's no need to dedicate precious desk space to another pair or disrupt your workflow to plug in headphones.
  • Fewer edges, greater concentration
    Minimized edges ensure maximum concentration. The virtually edge-free screen allows you to see the entire image, and also provides a virtually uninterrupted view in a dual-monitor configuration. View more content at once without distractions, and get more done in your screen time.
  • True color from every angle
    Now the whole team can see exactly what's on the screen. The IPS panel preserves the brilliance and clarity of colors across every inch of the screen. Work comfortably on the large, productivity-boosting screen, while enjoying precise nuances from 178° around, without color alteration.
  • Comprehensive connectivity
    Countless connection possibilities. The complete port package offers you all the connectivity you need in today's working environment. Plug in all your devices, such as laptops, desktops and tablets, and connect your USB hub to the USB 3.0 port for easy access to your small or personal electronic devices.
  • Fresh eyes for greater efficiency
    With well-protected eyes, it's easier to stay focused for longer. Advanced eye comfort technology reduces eye fatigue for greater concentration and productivity. Flicker Free technology permanently eliminates tiring and irritating screen flicker, while Eye Saver mode reduces blue light emissions.
  • Perfectly adapted to your needs
    Superior design for exceptional versatility in everyday use. The screen is height-adjustable, tilting and swiveling, allowing you to view your work as you see fit. What's more, the sleek, elegant design will add a touch of style to your desktop, and is VESA-compatible for easy installation.
  • An energy-saving display
    Smart Eco Saving technology saves up to 10% energy while maintaining image quality. In fact, this technology reduces the brightness of the black parts of the screen and simultaneously increases RGB amplification, so that the screen is perfectly bright.
Samsung S24R650FDU - SR65 Series - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class E
Energy Consumption per Year
26 kWh
Power Consumption (On mode)
18 W
Adaptive-Sync Technology
AMD FreeSync
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (NTSC 1976)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
Dark grey/blue
53.94 cm x 20.05 cm x 47.38 cm
5.1 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class E
26 kWh
Diagonal Size
24"
Viewable Size
23.8"
AMD FreeSync
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% (NTSC 1976)
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus
Dark grey/blue
53.94 cm x 20.05 cm x 47.38 cm - with stand
5.1 kg
VGA , DisplayPort 1.2 , HDMI , Audio line-in , Headphones , 2 x USB 3.0 , 2 x USB 2.0
Mechanical
Tilt Angle
-5/+24
Swivel Angle
90
Rotation Angle
-2/+92
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
18 W
18 kWh/1000h
Power Consumption (Typical)
18 Watt
Power Consumption Stand by
0.4 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 53.94 cm - depth: 20.05 cm - height: 47.38 cm - weight: 5.1 kg , Without stand - width: 53.94 cm - depth: 7.16 cm - height: 31.97 cm - weight: 3.3 kg
Shipping Width
60.5 cm
Shipping Depth
21.5 cm
Shipping Height
38.5 cm
Shipping Weight
6.7 kg
Sustainability Information
ENERGY STAR Certified
Diagonal Size: 24in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Samsung
