With a beautiful semi-transparent finish, Samsung's Touch of Color technology optimizes your living space and completely sets it apart. The bezels on all four sides are super slim, especially the one running along the bottom. Not only does it deliver a clean and modern look, it naturally draws your eyes to the screen.
Delivers a 178° wide viewing angle horizontally and vertically for an optimal and comfortable viewing experience from any angle. A truly fast 4 ms response time lets you see even the fastest on-screen motion clearly and smoothly with less motion blur, judder, and ghosting.
Slim ToC
With a beautiful semi-transparent finish, Samsung's Touch of Color technology optimizes your living space and completely sets it apart. -
Slim narrow bezel
The bezels on all four sides are super slim, especially the one running along the bottom. Not only does it deliver a clean and modern look, it naturally draws your eyes to the screen. -
T-shaped stand
Using touch of color for the T-shape stand completes the ensemble with a refined, minimal finish. -
Wide viewing angle
Delivers a 178° wide viewing angle horizontally and vertically for an optimal and comfortable viewing experience from any angle. -
Eye saver mode
Unlike other colors emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye saver mode optimizes your viewing comfort by smartly reducing blue light emissions at the touch of a button. -
Flicker Free technology
Flicker Free technology reduces screen flickering for a more comfortable viewing experience. -
Eco saving plus
Eco-saving technology reduces screen brightness for increased energy efficiency. In addition to the two standard manual settings (minimum at 25% and maximum at 50%), there is now an auto setting that reduces energy up about 10%, based on the luminescence of the screen's black sections. The screen brightness transitions fluidly while simultaneously saving energy. -
Enjoy smooth images even during fast moving scenes
A truly fast 4 ms response time lets you see even the fastest on-screen motion clearly and smoothly with less motion blur, judder, and ghosting. -
Upscale your view with better quality and picture
Magic upscale improves resolution of lower quality images and video so you can enjoy enhanced quality regardless of the original source.
- Samsung S24E391HL - SE391 Series - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 30 kWh
- Power Consumption (On mode)
- 21 W
- Panel Type
- Plane to Line Switching (PLS)
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Tilt
- Voltage
- AC 120/230 V
- High glossy white
- 54.83 cm x 18.19 cm x 40.9 cm
- 4.02 kg
- Environmental Standards
- ENERGY STAR Qualified
- IEC 62087 Edition 2
- Display Type
- Energy Class
- Class A
- 30 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.6"
- Panel Type
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eco Saving Plus, Eye Saver Mode
- High glossy white
- 54.83 cm x 18.19 cm x 40.9 cm - with stand
- 4.02 kg
- VGA , HDMI
Mechanical
- Tilt
- Tilt Angle
- -2/+15
- PVC free
- Cables Included
- 1 x VGA cable
- Power Supply
- External
- Input Voltage
- AC 120/230 V
- 21 W
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by
- 0.3 Watt
- OS Required
- Apple MacOS, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 54.83 cm - depth: 18.19 cm - height: 40.9 cm - weight: 4.02 kg , Without stand - width: 54.83 cm - depth: 6.99 cm - height: 33.33 cm - weight: 3.47 kg
Sustainability Information
- ENERGY STAR Certified
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
