Samsung S24E200BL 23.6" 1920x1080 5ms VGA DVI LED Monitor
Quicklinx: BKGWWS00 Mfr#: LS24E20KBL/EN
Select:
  • 23.6"
The SE200 Series provides an environmentally friendly, user friendly and budget friendly desktop monitor solution for your business. A simple and easy to use design, a matte black bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel make this 23.6" monitor a perfect value for everyday tasks.
  • Environmentally friendly
    With 30% recycled plastic, less than 0.1W off-mode power consumption, Eco features to reduce power consumption when the monitor is in use and fully recyclable packaging, this is the perfect value monitor for the environmentally-conscious business.
  • Impressive picture quality
    The LED-backlit LCD screen delivers sharp, bright and beautiful images. Mega infinity dynamic contrast ratio helps to ensure subtle detail even in the lights and darks, and MagicAngle technology delivers quality color even when viewed off-angle.
  • Slim design that fits any desk
    The sleek, stylish design and low profile stand take up less desk space and contribute to a cleaner-looking office. The built-in cable management feature also adds to a clutter-free work environment.
Samsung S24E200BL - SE200 Series - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2715 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72% (NTSC 1976)
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
55.46 cm x 18.5 cm x 41.27 cm
4.06 kg
Environmental Standards
ENERGY STAR Qualified
TUV, C-Tick, EN55022, SASO, EN55024, CISPR 22, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, UL60950-1, GB 4943-2011, GB 17625.1-2012, IEC60950-1
3-year warranty
Display Type
Diagonal Size
23.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% (NTSC 1976)
Response Time
5 ms
Vertical Refresh Rate
60 Hz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus
55.46 cm x 18.5 cm x 41.27 cm - with stand
4.06 kg
VGA , DVI
Mechanical
Tilt
Tilt Angle
-1/+20
VESA Mounting Interface
100 x 100 mm
PVC free
1 x VGA cable
Input Voltage
AC 120/230 V
Power Consumption (Typical)
22 Watt
Power Consumption Stand by
0.1 Watt
Power Consumption Sleep
0.1 Watt
Windows 8.1
Dimensions & Weight Details
With stand - width: 55.46 cm - depth: 18.5 cm - height: 41.27 cm - weight: 4.06 kg , Without stand - width: 55.46 cm - depth: 7.81 cm - height: 33.05 cm - weight: 3.72 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
