Samsung S24D400GAU 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor
Quicklinx: J5XYWS00 Mfr#: LS24D400GAUXXU
More than 50 In Stock
£84.83 ex VAT
£101.79 inc VAT
The Samsung S24D400GAU is a 24-inch desktop LED-backlit LCD monitor designed to enhance your viewing experience with vivid Full HD resolution of 1920 x 1080. Featuring a pixel pitch of 0.2767 mm, this monitor delivers sharp and clear images with a brightness level of 250 cd/m2. The dynamic contrast ratio of 1000:1, along with Mega Dynamic Contrast Ratio technology, ensures deeper blacks and brighter whites for a more immersive visual experience. With a fast response time of 5 ms and a refresh rate of 100 Hz, it minimizes blurring, ideal for gaming and fast-paced video content. The monitor supports a wide color gamut of 72% (CIE 1931), allowing for display of 16.7 million colors, which brings images to life with enhanced detail and accuracy.
Designed with user comfort in mind, the monitor features Eye Saver Mode and Flicker-Free technology that reduces eye strain, making it suitable for extended use. An adjustable height and tilt capability coupled with swivel and pivot functions provide customizable positioning, ensuring optimal comfort and viewing angles. The monitor includes a built-in USB 2.0 hub for easy connectivity, and the sleek, ultraslim design minimizes its footprint in any workspace. With multiple input options including HDMI and DisplayPort, this monitor offers versatility for various devices and is made partially from recycled plastic, reinforcing Samsung's commitment to environmental sustainability.
Samsung S24D400GAU - S40GD Series - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/2109453
Energy Class
Class C
Energy Consumption per Year
18 kWh
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 100 Hz
Pixel Pitch
0.2767 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931)
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Voltage
AC 100-240 V
54.07 cm x 21.9 cm x 49.77 cm
3.5 kg
Environmental Standards
TCO Certified, generation 10, for displays
HDCP 1.2, HDCP 1.4
Display Type
Energy Class
Class C
18 kWh
Diagonal Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2767 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% (CIE 1931)
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, Energy Saver, Image Size, Eye Saver Mode, Off Timer Plus, Super Slim Design, Auto Source Switch
54.07 cm x 21.9 cm x 49.77 cm - with stand
3.5 kg
2 x HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.2) , Headphone jack (mini-jack) , 2 x USB 2.0 downstream , USB 2.0 upstream (Type B)
Mechanical
Tilt Angle
-3/+25
Swivel Angle
90
Rotation Angle
184
Height Adjustment
105 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 16.9% recycled plastic
1 x HDMI cable
HDCP 1.2, HDCP 1.4
Security Slot Type
Kensington security slot
Input Voltage
AC 100-240 V
12 kWh/1000h
Power Consumption (Typical)
12 Watt
Power Consumption (Max)
45 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 54.07 cm - depth: 21.9 cm - height: 49.77 cm - weight: 3.5 kg , Without stand - width: 54.07 cm - depth: 3.98 cm - height: 32.04 cm - weight: 2.3 kg
Shipping Width
58.5 cm
Shipping Depth
44.7 cm
Shipping Height
10.9 cm
Shipping Weight
4.8 kg
Sustainability Information
TCO Certified
10 °C
10 - 80% (non-condensing)
Brand: Samsung
