The Samsung S24A850DW is a professional monitor that combines high performance with low power consumption. Using as much as 50% less energy than others, this versatile monitor has environmental benefits as well as for productivity and viewing experience. Its wide WQHD display offers resolutions of up to 2560 x 1440 pixels and sRGB support mean a faithful reproduction of images from your digital camera, HD camcorder or other device.
Picture perfect, natural-looking images
Whether it's video from an HD camcorder or photos from your digital camera, sRGB support makes sure that nature looks just as natural on your Samsung Monitor as it did when you shot it or filmed it. No matter what digital device the image was captured on, it's as picture perfect on screen as Mother Nature intended it to be. So you can view, edit, and save images in their original format with no picture quality degradation whatsoever — which translates to 100% pure digital satisfaction. -
Conserves Energy and Preserves the Environment
Engineered with the ecologically responsible homeowner in mind, the Samsung monitor reduces power consumption by 40%, making it much more efficient than conventional monitors. By reducing the number of LED and defaulting to standby power, which requires less than 0.3W as opposed to the typical 1.0W, the Samsung monitor is poised to make a difference. How big a difference? If your monitor saves 120W each day, that's the annual equivalent of eliminating 10.8kg of CO2emitted from an oil-burning power plant—which produces the same effect as planting four pine trees. -
See more content with unbelievable screen resolution
The Samsung SA850 Monitor showcases an astounding WQHD display with 2560 x 1440 pixel resolution, which is four times the resolution of HD (720p). It is perfect for businesses and industries that rely on access to extremely fine monitor detail. The wide screen, which features dual link DVI and display port, allows for more detail to be viewed and is ideal for work places such as hospitals, clinics and studios. The enhanced screen resolution provides greater efficiency and quality, and really is the must-have business tool. -
See Your Work from the Best Possible Angle
Provide employees with an optimal viewing experience in the office with the reasonably priced Samsung Business Monitor. While conventional monitors have a viewing angle of 170 degrees horizontally, the Samsung monitor has an extra wide viewing angle of 178 degrees. The additional 8 degrees is particularly useful when sharing on-screen information with one or more coworkers or presenting your ideas to clients. The Samsung Business Monitor has improved its vertical viewing angles by 18 degrees, making it the perfect display for giving presentations in front of a large audience or when viewing other content such as a video. -
See perfect colours from wherever you sit
Maximise your viewing experience with Samsung's superior PLS technology (Plane to Line Switching). Regular screens suffer from what is called Colour Shift, which reduces the picture quality and colour when viewed from an acute angle. The SA850, which can cover an amazing 178° viewing angle both vertically and horizontally, boasts a crisp and detailed picture by maintaining true-to-life colour, even when viewed from extreme angels, so the experience is always vivid and brilliant.
- Samsung S24A850DW - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Native Resolution
- 1920 x 1200
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, swivel, tilt
- Matte black
- 58.5 cm x 22.4 cm x 44.7 cm
- 5.6 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Plug and Play, DDC-2B
- Display Type
- Diagonal Size
- 24"
- Native Resolution
- 1920 x 1200
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Power off timer, MagicColor, HDCP, MagicAngle, MagicBright 3, Mega Contrast, Eco Light Sensor, Eco Motion Sensor
- Matte black
- 58.5 cm x 22.4 cm x 44.7 cm - with stand
- 5.6 kg
- DisplayPort , DVI-D , VGA , 4 x USB 3.0
Mechanical
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm, 100 x 200 mm
- Power Supply
- External
- Power Consumption (Typical)
- 64 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 58.5 cm - depth: 22.4 cm - height: 44.7 cm - weight: 5.6 kg , Without stand - width: 58.5 cm - depth: 4.1 cm - height: 37.4 cm
- Shipping Width
- 63 cm
- Shipping Depth
- 17.9 cm
- Shipping Height
- 44.3 cm
- Shipping Weight
- 7.8 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
