Samsung S24A600UCU 24" 2560x1440 5ms HDMI DP USB-C LED Monitor
Quicklinx: GBJ4WS00 Mfr#: LS24A600UCUXXU
Diagonal Size: 24in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: None
Interfaces: USB-C, DisplayPort, HDMI
More than 50 In Stock
£249.99 ex VAT
£299.98 inc VAT
Quad HD LED display
See more detail with the Samsung LS24A600UCUXXU Quad HD 24" LED Monitor. Its Quad HD display with HDR10 gives you rich contrast and vibrant colours, so everything on screen looks crisp and clear.
AMD FreeSync
Immerse yourself in your movies and games with AMD FreeSync. It matches the monitor refresh rate with your graphics card, so you get smooth, lag-free images. And with the wide viewing angles you can see everything clearly, even from the side or above.
Intelligent Eye Care
Stay comfortable while you work – the monitor's Eye-Saver mode protects your eyes during long sessions at the computer. It also uses flicker-free technology, so you can work or relax without any distracting screen flicker.
  • Discover the details
    Experience details not seen before. When watching your favorite movie or working on your latest project, benefit from outstanding levels of precision up to 1.7x the pixel density of Full HD. QHD provides more room for multitasking or taking in beautiful videos and images.
  • See greatness from any angle
    Optimized for professional work environments. Samsung high resolution monitors feature an IPS panel delivering crystal clear color quality and a wide viewing angle of 178°. Every user can expect a great viewing experience from any angle, in vivid and vibrant color without washing or fade.
  • Enjoy a billion colors with incredible depth
    Enjoy any content in stunning color accuracy and detail. With a wide range of colors, near limitless hues and HDR10, which makes dark colors darker and the brightest colors even brighter, every piece of content becomes a joy to look at and can be experienced exactly as the creator intended.
  • Relieve your eyes from strain
    Keep your eyes fresh and strain-free. For those late-night projects, brightness and color temperature adjust automatically for optimization in any environment. With TUV-certified eye care technology, Samsung protects eyes against excessive blue light with eye saver mode and a flicker free feature.
  • Maximize comfort, minimize distractions
    Position your monitor for optimal comfort. Borderless design, VESA mount compatibility and a variety of tilt, swivel and pivot control points allow you to mount your monitor in any environment. In addition, a slim metal stand and narrow depth take up less desk space for a clean, seamless work setup.
  • Stay in sync with the action
    Make your entertainment experience more fluid than ever. AMD FreeSync keeps your monitor and graphics card refresh rate in sync to reduced image tear and stutter. Movies and games have no interruptions and even fast action scenes are ultra-responsive and smooth.
Samsung S24A600UCU - S60UA Series - LED monitor - 24" - HDR
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/438650
Energy Class
Class F
Power Consumption (On mode)
19 W
Adaptive-Sync Technology
AMD FreeSync
Daisy Chaining
USB 3.0/USB-C hub, USB PD 65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 at 75 Hz
Brightness
300 cd/m²
Contrast Ratio
1000:1
HDR Capable
HDR10
Response Time
5 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Voltage
AC 120/240 V
54.23 cm x 19.64 cm x 53.08 cm
5 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
TUV
Display Type
Energy Class
Class F
Energy Class (HDR)
Class G
Diagonal Size
24"
AMD FreeSync
Daisy Chaining
Built-in Devices
USB 3.0/USB-C hub
USB Power Delivery
65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
1000:1
HDR Format
HDR10
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture by picture, game mode, Mega Dynamic Contrast Ratio, Eco Light Sensor, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, Picture-in-Picture, Adaptive Picture, Auto Source Switch, USB-C Power Boost
54.23 cm x 19.64 cm x 53.08 cm - with stand
5 kg
DisplayPort 1.2 , DisplayPort 1.2 output , HDMI , Headphones , USB 3.0 , 2 x USB 2.0 , USB-C (power up to 65W)
Mechanical
Tilt Angle
-2/+25
Swivel Angle
60
Rotation Angle
-2/+92
Height Adjustment
120 mm
VESA Mounting Interface
75 x 75 mm
1 x HDMI cable , 1 x USB-C cable
TUV
Security Slot Type
Kensington security slot
Input Voltage
AC 120/240 V
19 W
19 kWh/1000h
Power Consumption HDR (On mode)
24 kWh/1000h
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 54.23 cm - depth: 19.64 cm - height: 53.08 cm - weight: 5 kg , Without stand - width: 54.23 cm - depth: 4.13 cm - height: 32.71 cm - weight: 2.9 kg
Shipping Width
61.6 cm
Shipping Depth
41.6 cm
Shipping Height
17.6 cm
Shipping Weight
6.4 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
Diagonal Size: 24in
Response Time: 5ms
Speakers: None
Interfaces: USB-C
Interfaces: DisplayPort
Interfaces: HDMI
Brand: Samsung
