Samsung S23A700 23IN LED DVI/HDMI TILT STAND
Quicklinx: 7TVPWS00 Mfr#: LS23A700DS/EN
  • High-Definition Multimedia Interface (HDMI)
Upgrade your viewing experience with a display solution that offers high-quality 3D imaging as well as stunning picture quality. The Samsung S23A700D monitor uses sophisticated 3D HyperReal Engine technology, which manipulates contrast, colour, motion and more to create awe-inspiring three-dimensional visuals. Your movie collection and favourite TV shows can join you in the 3D revolution when you use 3D Converter to transform 2D content. You'll experience better viewing in 2D, too - Real 120Hz picture clarity ensures that you enjoy a clearer picture and smoother motion, whatever you're watching. With the S23A700D monitor, you'll discover a new standard of 3D quality and viewing comfort.
  • Catch every detail with Real 120Hz
    Samsung's 3D LED Monitor SA700 is ready to redefine your whole world of entertainment through its enhanced Real 120Hz picture clarity. Pictures will surprise you with their crystal-clear sharpness and smoothness. Whether it is 2D or 3D, action packed scenes or intimate close-ups will be so true-to-life that you will mistake them for reality. The Real 120Hz ensures that images are not lost and sequences are super smooth. This makes for a more comfortable and enjoyable experience. And when you factor in the amazing brightness, this 3D experience will have you totally mesmerised.
  • See true colours with Photo Accuracy 100%
    Nothing beats true-to-life clarity and colour. Samsung's Photo Accuracy 100% ensures that your captured moments, whether on digital camera or camcorder, are represented exactly as you remember them. The Photo Accuracy distinguishes itself with its sRGB colour, which is the standard colour of digital devices such as monitors, digital cameras and scanners, and brings your captured moments to life without the annoying distortions. Samsung's 3D LED monitor SA700 screen reproduces colour for crystal clear, realistic images and is the perfect way to relive precious memories.
  • See 2D in a new dimension with a 3D converter
    Enjoying 2D images in 3D may seem like a fantasy, but with Samsung it is a brilliant reality. At the push of a button, Samsung's 3D Converter transforms your favourite TV programmes or movies with amazing 3D-depth. It will reinvent your favourite 2D content. And with the 3D visual adjustment feature, you can even customise your 3D experience to match your particular likes. It is a new level of visual comfort.
  • Take in richer pictures with Ultra Clear Panel
    Don't settle for a viewing experience that is hampered by unnecessary reflections and poor contrast ratios. Samsung's 3D LED monitor SA700 offers a perfect viewing experience with its Ultra Clear Panel. The vibrant and rich images are created through the panel's ability to avoid diffused reflections from external light such as sunlight, thus minimising glares. The result is superb picture quality that is sharper and high in contrast ratio, revealing deeper blacks and brighter colours. It is a dynamic visual experience that you've been waiting for.
  • See the next level with the 3D HyperReal Engine
    Samsung achieves the very highest standard in Extreme 3D imaging through its intuitive 3D HyperReal Engine. It is a brain-like technology that allows Samsung's 3D LED Monitor SA700 to control features like colour, contrast, 3D effects and motion for mind blowing results. Full HD 3D visuals are so life-like and crystal-clear that they ensure that your experience is not only captivating but also comfortable.
Samsung S23A700D - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D
Display Position Adjustments
Tilt
Glossy black
53.4 cm x 19.7 cm x 39.5 cm
2.9 kg
Microsoft Certification
Compatible with Windows 7
Plug and Play, DDC-2B
Display Type
Diagonal Size
23"
3D Technology
Alternate-frame sequencing
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Power off timer, MagicColor, MagicAngle, MagicBright 3, Mega Dynamic Contrast Ratio, 3D HyperReal Engine, 2D to 3D conversion, Real 120Hz Input
Glossy black
53.4 cm x 19.7 cm x 39.5 cm - with stand
2.9 kg
HDMI , DVI-D (dual link) , Audio line-out
Mechanical
Tilt
Power Supply
External
Power Consumption (Typical)
44 Wh
Power Consumption Stand by / Sleep
1 Watt
Dimensions & Weight Details
With stand - width: 53.4 cm - depth: 19.7 cm - height: 39.5 cm - weight: 2.9 kg , Without stand - width: 53.4 cm - depth: 5 cm - height: 32 cm
Shipping Width
60 cm
Shipping Depth
11 cm
Shipping Height
44 cm
Shipping Weight
4.7 kg
