Note's signature tool comes built in
S Pen keeps the legacy of Galaxy Note alive. Capture scribbles, strokes of genius and everything in between with the built-in S Pen. You can even use it to snap pics without needing to set a selfie timer. -
Get ready to become your group's go-to photographer
Get ready to become your group's go-to photographer. They have packed Galaxy's biggest sensor, light-absorbing pixels and video stabilization technology into one epic camera for life's most share-worthy moments. -
Low light, camera, action
Take crisp photos and videos, no matter the lighting. Galaxy's most advanced camera sensor and fastest processor reduce noise in low light for stunning shots. -
200MP wow-worthy resolution
They nearly doubled the resolution on the Wide-Angle Camera, delivering images so clear you can zoom way in to find hidden masterpieces. Then crop and create whole new compositions from your existing shots. Working behind the scenes of every shot is an all-new adaptive pixel sensor for a Gallery of vibrant, crisp 200-megapixel photos in any light. -
RAW power, from snap to edit
Switch into Expert RAW to finesse in greater detail. Snap in 50MP for detailed, dynamic frames. -
Power for those who don't pause
Game at full throttle and smoothly switch between apps with fast processor ever. -
Bring on the boss battles
Meet the long-lasting battery made to fuel your victories. This intelligent 5000 mAh (typical) battery saves power for go time, so you can game and stream into the night. -
A bright future in sight
Dynamic AMOLED 2X delivers clear, colorful details on screen, whether dimmed low or on full brightness. 120 Hz technology intelligently optimizes the refresh rate to smooth out action and save on battery.
- Samsung Galaxy S23 Ultra - Enterprise Edition - phantom black - 5G smartphone - 256 GB - GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- SM-S918B/DS
- Display
- OLED display - 3088 x 1440 pixels - 6.8" - 500 ppi - (120 Hz) - Infinity-O Dynamic AMOLED 2X - HDR - Corning Gorilla Glass Victus 2 (scratch resistant glass)
- Processor
- Qualcomm Snapdragon 8 Gen 2 3.36 GHz (8-core)
- Memory
- RAM 8 GB / 256 GB
- Operating System
- Android 13 with Samsung One UI 5.1
- Main Camera
- 200 Megapixel - wide-angle lens - f/1.7 - focus: automatic laser auto focus: - laser focus
- Second Camera
- 12 Megapixel - ultra wide-angle lens - f/2.2
- Third Camera
- 10 Megapixel - telephoto lens - 10x optical zoom - f/4.9
- Fourth Camera
- 10 Megapixel - telephoto lens - 3x optical zoom - f/2.4
- Front Camera
- 12 Megapixel f/2.2 - automatic
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
- Wireless Interface
- NFC, Wi-Fi 6, UWB, Wi-Fi 6E, Bluetooth
- Security Devices
- Fingerprint reader (under display), face recognition
- Connectors
- USB-C
- Talk Time
- Up to 2940 minutes
- Wireless Charging Standards
- WPC, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
- Protection
- Dustproof, splashproof, water-resistant
- Phantom black
- 78.1 mm x 8.9 mm x 163.4 mm
- 233 g
- Repairability Index
- 8.2 (out of 10)
- Specific Absorption Rate (SAR)
- 0.963 W/kg (head) , 1.398 W/kg (body) , 2.95 W/kg (limb)
- 2-year warranty
- Product Type
- Smartphone
- SM-S918B/DS
- Form Factor
- Touch
- Protection
- 78.1 mm
- 8.9 mm
- 163.4 mm
- 233 g
- Body Colour
- Phantom black
- Body Material
- PET film, recycled glass, Armour Aluminium frame
- SAR Value
- 1.398 W/kg (body), 0.963 W/kg (head), 2.95 W/kg (limb)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Android 13
- User Interface
- Samsung One UI 5.1
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou, Galileo, QZSS
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Dual-SIM
- Payment Technology
- Samsung Pay
- Input Device
- Multi-touch
Communications
- Data Transmission
- FDD-LTE, TDD-LTE, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N1, n2, n3, n5, n7, n8, n20, n28, n38, n41, n66, n75, n77, n78, n40, n25, n12
- 5G NR Frequency
- FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, SDL DL 1500+, TDD TD 3700, TDD TD 3500, TDD 2300, FDD 1900, n12
- NFC, IEEE 802.11a/b/g/n/ac/ax, Ultra-Wideband (UWB), Wi-Fi 6E, Bluetooth 5.3
Phone Features
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, barometer, gyro sensor, hall sensor, geomagnetic sensor
- Security Devices
- Additional Features
- S Pen multi-input, Air View, MIMO technology, Screen Write, notification flashlight, Smart Select, Three microphones, Samsung KNOX, Smart View, Live message, Screen off memo, Samsung DeX support, Bixby Vision, Secure Folder function, TalkBack, Dual Audio, Intelligent Performance Enhancer, Samsung Smart Switch, AR Doodle, PENUP, Bixby key, Bluetooth Scalable Codec, Samsung Knox Vault, 2 years of product availability from launch date, 5 years of Security Maintenance Release, DisplayPort over USB Type-C, dual stereo speakers tuned by Dolby Atmos, Samsung Seamless Codec, 3 years enhanced support, Samsung Wallet, Samsung Knox Suite
Media Player
- Supported Digital Audio Standards
- WAV, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, DSD, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
- Supported Digital Video Standards
- MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Surround sound, Dolby Digital sound, amplify ambient sound
- Clock Speed
- 3.36 GHz
- Processor Core Qty
- 8-core
- RAM
- LPDDR5 SDRAM - 8 GB
- Internal Memory Capacity
- 256 GB
- User Memory
- 216.6 GB
Front Camera
- Sensor Resolution
- 12 Megapixel
- Lens Aperture
- F/2.2
- Focus Adjustment
- Automatic
- Field of View (FoV)
- 80 degree(s)
- Pixel Size
- 1.12 µm
- 2PD AF
Main Camera
- Sensor Resolution
- 200 Megapixel
- Optical Image Stabiliser
- Dual OIS (Optical Image Stabilisation)
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.7
- 85 degree(s)
- Pixel Size
- 0.6 µm
- Focus Adjustment
- Automatic
- Laser Auto Focus
- Self-Timer Delay
- Special Effects
- Super HDR, face retouch, Grid Line, selfie colour tone
- Camera Modes
- Panorama, Slow motion mode, Pro mode, HYPERLAPSE, Super Slow-mo, Flowers, Greenery, Trees, Sky, Beaches, Watersides, Snow, Backlit, Text, Food, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view, Portrait, Night, Motion Photo, Mountain, Filter mode, Single Take, Pro Video, Portrait video, Director's View, Expert RAW mode, My Filter mode, Astrolapse
- HDR Mode
- Auto HDR mode
- Light Source
- High CRI LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, Super slow motion video 1920 x 1080 (1080p) at 960 fps, 7680 x 4320 (UHD 8K) at 24fps, Hyperlapse 4K video support at 30 fps, Super Steady 1080p video support at 60 fps, 7680 x 4320 (UHD 8K) at 30fps, 3840 x 2160 (4K) HDR10+ at 60 fps, Director's View 1920 x 1080 (1080p) at 30 fps
- Blink detection, QR-code scanner, RAW image capture, VDIS (Video Digital Image Stabilisation), Tracking AF, Quick Share, Scene Optimiser, Lens smudge, Flaw detection, Shot suggestions, blur detection, HDR10+ recording, Super steady, backlighting detection, Quick Measure, Zoom-In Mic, HEIF image capture, Take 33MP still photos while playing 8K video, Single Take, AR Doodle, HEVC (High Efficiency Video coding) support, Auto framing, UW shape correction, Auto FPS, object eraser, Digital zoom up to 20x for video, High Bitrate, 360 Audio Recording
Second Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- 120 degree(s)
- Pixel Size
- 1.4 µm
Third Camera
- Sensor Resolution
- 10 Megapixel
- Optical Zoom
- 10x
- Lens Type
- Telephoto lens
- Lens Aperture
- F/4.9
- 11 degree(s)
- Pixel Size
- 1.12 µm
- 100x Super Resolution Zoom, Space Zoom
Fourth Camera
- Sensor Resolution
- 10 Megapixel
- Optical Zoom
- 3x
- Lens Type
- Telephoto lens
- Lens Aperture
- F/2.4
- 36 degree(s)
- Pixel Size
- 1.12 µm
Display
- OLED display
- Technology
- Diagonal Size
- 6.8"
- Display Resolution
- Display Format
- QHD+
- Pixel Density
- 500 ppi
- Max Brightness
- 1750 cd/m²
- Colour Depth
- 16.7 million colours
- HDR
- HDR Technology
- HDR10+
- Enhancement Technology
- Vision Booster technology
- Refresh Rate
- 120 Hz
- Touch Sampling Rate
- 240 Hz
- Contrast Ratio
- 3000000:1
- Protection
- AOD(Always On Display), Video Wallpaper, 100% DCI-P3
- Connector Type
- USB Type-C - 24 pin USB-C
- Capacity
- 5000 mAh
- Fast Charging Technology
- Qualcomm Quick Charge 2.0, Adaptive Fast Charging, Samsung Super Fast Charging, Power Delivery 3.0
- Wireless Charging
- Talk Time
- 2940 minutes
- Run Time Details
- Talk (4G): up to 2940 min , Active online usage (LTE): up to 25 hrs , Active online usage (Wi-Fi): up to 25 hrs , Playback (wireless video): up to 26 hrs , Playback (wireless audio): up to 99 hrs
- VDE, IP68, HAC (Hearing Aid Compatible), EcoLogo, IEC 61960, Carbon Trust
- Included Accessories
- SIM card removal tool, S Pen, USB-C to USB-C cable
- Limited warranty - 2 years
- Regional Warranty Exceptions
- Spain - 3 years
Sustainability Information
- 8.2 (out of 10)
- Max Depth of Water Resistance
- 1.5 m
