The Samsung SF350 monitor has a slim panel. Its simple circular stand elegantly complements the slender curved panel while its horizontal patterning on the rear panel provides a stylish, contemporary finish.
Optimized for viewing comfort
The SF350 reduces blue light emissions - which stimulate the retina more than other color wavelengths and reduces eye fatigue to provide a more comfortable viewing experience. -
Extra-wide viewing angles for the perfect view
Enjoy extra-wide viewing angles that enable everyone to enjoy the perfect view from any position, whether sitting back to relax or gathered around with your friends.
- Samsung S22F350FHU - SF350 Series - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/362922
- Energy Class
- Class G
- Energy Consumption per Year
- 29 kWh
- Power Consumption (On mode)
- 20 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 200 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (NTSC 1976)
- Input Connectors
- HDMI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Shiny black
- 50.86 cm x 20.65 cm x 39.54 cm
- 2.8 kg
- Display Type
- Energy Class
- Class G
- 29 kWh
- Diagonal Size
- 22"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 200 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72% (NTSC 1976)
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eye Saver Mode
- Shiny black
- 50.86 cm x 20.65 cm x 39.54 cm - with stand
- 2.8 kg
- VGA , HDMI
Mechanical
- Tilt
- Tilt Angle
- -1/+22
- VESA Mounting Interface
- 75 x 75 mm
- Input Voltage
- AC 120/230 V
- 20 W
- Power Consumption SDR (On mode)
- 20 kWh/1000h
- 0.3 Watt
- OS Required
- Windows 10
- Dimensions & Weight Details
- With stand - width: 50.86 cm - depth: 20.65 cm - height: 39.54 cm - weight: 2.8 kg , Without stand - width: 50.86 cm - depth: 8.01 cm - height: 30.2 cm - weight: 2.3 kg
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
