Samsung S22F350H 22" Display
Quicklinx: D3NRWS00 Mfr#: LS22F350FHUXEN
Select:
  • 21.5"
The Samsung SF350 monitor has a slim panel. Its simple circular stand elegantly complements the slender curved panel while its horizontal patterning on the rear panel provides a stylish, contemporary finish.
  • Optimized for viewing comfort
    The SF350 reduces blue light emissions - which stimulate the retina more than other color wavelengths and reduces eye fatigue to provide a more comfortable viewing experience.
  • Extra-wide viewing angles for the perfect view
    Enjoy extra-wide viewing angles that enable everyone to enjoy the perfect view from any position, whether sitting back to relax or gathered around with your friends.
Samsung S22F350FHU - SF350 Series - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class G
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72% (NTSC 1976)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
Shiny black
50.86 cm x 20.65 cm x 39.54 cm
2.8 kg
Display Type
Energy Class
Class G
29 kWh
Diagonal Size
22"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% (NTSC 1976)
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eye Saver Mode
Shiny black
50.86 cm x 20.65 cm x 39.54 cm - with stand
2.8 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-1/+22
VESA Mounting Interface
75 x 75 mm
Input Voltage
AC 120/230 V
20 W
20 kWh/1000h
Power Consumption (Off Mode)
0.3 Watt
Windows 10
Dimensions & Weight Details
With stand - width: 50.86 cm - depth: 20.65 cm - height: 39.54 cm - weight: 2.8 kg , Without stand - width: 50.86 cm - depth: 8.01 cm - height: 30.2 cm - weight: 2.3 kg
10 °C
10 - 80% (non-condensing)
