The Samsung LED Business Monitor SA650 has been designed to enhance work conditions and efficiency. Featuring Front Tactile Buttons, the SA650 minimizes costly errors found with high usage, which is a common problem with touch type button monitors. Furthermore, with its smarter design, users can still access these buttons when wall mounted, which can be an issue when monitors feature side panel buttons. Adding to the visual experience, the SA650 features a Narrow Matt Bezel. This reduces distraction around display area and delivers an experience that is immersive and engaging.
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SA650 is the perfect choice. From physically moving the monitor with the carrying handle to quickly installing, the SA650 is ready to deliver an efficient and clean work space. The SA650 is also equipped and prepared for you as a VESA Wall mount, providing a multi-screen or wall mounted monitor. Optimizing your office space is now easily achieved with the Samsung LED Business Monitor SA650.
The Samsung LED Business Monitor SA650 has been designed to help boost work efficiency, delivering a tailored experience with its choice of viewer settings. The height-adjustable stand ensures that the screen can always be set at the optimal eye level, which enhances the visual experience while also helping maintain the viewer's body posture. Other features include the tilt and pivot capabilities, which not only increase comfort levels but also introduce new ways of working. The SA650 Monitor can rotate 90 degrees, allowing for more appropriate view depending on the work. So, now you can take convenience and efficiency to amazing heights with the Samsung LED Business Monitor SA650.
A business tool that produces crystal-clear images
The Samsung Business Monitor produces the highest level of static contrast ratio of 3,000:1. Compared to competitive models in the same class, the Samsung Business Monitor possesses a contrast ratio that is three times higher. This provides users with clear and sharp image representation which is a strong benefit for businesses that work heavily around graphics and other high-resolution images. -
A monitor designed to match business needs
The Samsung LED Business Monitor SA650 has been designed to enhance work conditions and efficiency. Featuring Front Tactile Buttons, the SA650 minimizes costly errors found with high usage, which is a common problem with touch type button monitors. Furthermore, with its smarter design, users can still access these buttons when wall mounted, which can be an issue when monitors feature side panel buttons. Adding to the visual experience, the SA650 features a Narrow Matt Bezel. This reduces distraction around display area and delivers an experience that is immersive and engaging. -
Maximize workspace with the efficient handle VESA wall mount
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SA650 is the perfect choice. From physically moving the monitor with the carrying handle to quickly installing, the SA650 is ready to deliver an efficient and clean work space. The SA650 is also equipped and prepared for you as a VESA Wall mount, providing a multi-screen or wall mounted monitor. Optimizing your office space is now easily achieved with the Samsung LED Business Monitor SA650. -
Conveniently adjust monitor height, tilt, and perspective
The Samsung LED Business Monitor SA650 has been designed to help boost work efficiency, delivering a tailored experience with its choice of viewer settings. The height-adjustable stand ensures that the screen can always be set at the optimal eye level, which enhances the visual experience while also helping maintain the viewer's body posture. Other features include the tilt and pivot capabilities, which not only increase comfort levels but also introduce new ways of working. The SA650 Monitor can rotate 90 degrees, allowing for more appropriate view depending on the work. So, now you can take convenience and efficiency to amazing heights with the Samsung LED Business Monitor SA650. -
Save energy and see the results with the energy tree
Take the guess work out of eco savings with Samsung new Energy Tree feature. For the first time, you can now know exactly how much energy you are saving through your eco modes such as the Eco light sensor and the Eco motion sensor. Through an intuitive energy saving status, which can be displayed either intuitively or graphically, you can keep tabs on your efforts to make the world a better place. -
Control power consumption, conserve energy
Eco saving makes saving energy easy. It adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes (50%, 25% and Power Saving off), you can really tailor your monitor use to meet your own personal needs. Samsung's commitment to saving energy is designed to help both you and the environment, and with up to 50% saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving. -
Gentle on the eyes and on the environment
Save electricity and hassle with Samsung's Eco light sensor. By adjusting screen brightness to match your surrounding environment, the SA650's Eco light sensor creates a brilliant visual display while also minimizing your energy consumption. You will benefit from a more comfortable viewing experience that is far better for the environment. Monitor brightness is adjusted to match your ambient light, which ensures that the screen is highly visible and appropriately set for your eyes. So, in a dark room the screen will reduce brightness, but when sitting in a room with plenty of light, it will increase brightness. The Eco light sensor is simply perfect for modern living - helping you conserve energy and keep comfortable. -
Save energy with smart motion technology
Step into the future with the SA650 monitor, which utilizes the very latest in motion sensors to create a monitor that hangs on your every movement. With a built-in PIR (Pyrolectric Infrared Ray) sensor, the SA650 automatically detects movement within a specified area in front of the screen. This allows your monitor to automatically dim or power off, and then power back on or brighten once detecting a nearby viewer. Eco motion sensor is the easiest way to conserve energy. -
See your work from the best possible angle
Provide employees with an optimal viewing experience in the office with the reasonably priced Samsung Business Monitor. While conventional monitors have a viewing angle of 170 degrees horizontally, the Samsung monitor has an extra wide viewing angle of 178 degrees. The additional 8 degrees is particularly useful when sharing on-screen information with one or more coworkers or presenting your ideas to clients. The Samsung Business Monitor has improved its vertical viewing angles by 18 degrees, making it the perfect display for giving presentations in front of a large audience or when viewing other content such as a video.
- Samsung S22E650D - SE650 Series - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- USB Hub
- Panel Type
- Plane to Line Switching (PLS)
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.24825 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (NTSC 1976)
- Input Connectors
- DVI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Black
- 50.43 cm x 21 cm x 48.94 cm
- 4.87 kg
- Environmental Standards
- ENERGY STAR Qualified
- C-Tick, EN55022, SASO, EN55024, CISPR 22, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, UL60950-1, GB 4943-2011, GB 17625.1-2012
- 3-year warranty
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Built-in Devices
- USB Hub
- Panel Type
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.24825 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72% (NTSC 1976)
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus
- Black
- 50.43 cm x 21 cm x 48.94 cm - with stand
- 4.87 kg
- VGA , DVI , DisplayPort , 2 x USB 2.0
Mechanical
- Tilt Angle
- -3/+25
- Swivel Angle
- 90
- Rotation Angle
- -1/+95
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- PVC free
- Cables Included
- 1 x VGA cable , 1 x USB cable
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 21 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.005 Watt
- OS Required
- Windows 10
- Dimensions & Weight Details
- With stand - width: 50.43 cm - depth: 21 cm - height: 48.94 cm - weight: 4.87 kg , Without stand - width: 50.43 cm - depth: 5.54 cm - height: 30.19 cm - weight: 3.27 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £143.67 |
StarTech.com Articulating Monitor Arm | In Stock | £132.69 |
StarTech.com Dual Monitor Stand | In Stock | £91.00 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £82.52 |
