Clear picture quality with fast response time
- Fast 5ms Response Time: See even fast on-screen motion clearly and smoothly with less motion blur, judder or ghosting.
- Full HD Resolution: Provides clean and crisp picture quality in 1920 x 1080 resolution so you can see all of your content clearly.
Easy on the eyes for a more comfortable viewing experience
- Eye Saver Mode: Unlike other colours emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye Saver Mode optimises your viewing comfort by smartly reducing blue light emissions at the touch of a button.
- Flicker Free: Flicker Free technology reduces screen flickering for a more comfortable viewing experience.
Save energy with energy-efficient features
- SMART Eco Saving: The SE200 reduces power consumption by 10% without a noticeable loss in picture quality thanks to eco-saving technology that automatically adjusts the brightness of the screen’s black sections while simultaneously adjusting the RGB gain values.
Eco-friendly materials with Intertek Green Leaf certification
- Recycled Plastics: All Samsung business monitors are made of 30% recycled plastics.
- PVC Free: Monitor mechanisms and circuits are constructed without PVC* making for an eco-friendly device, lessening environmental impact.
- Accessory Packaging: Samsung has reduced the LDPE (Low-Density Polyethylene) in accessory packaging from 100% to 80% by using bio-friendly Sugar cane (20%) as an alternative manufacturing material. Samsung packaging is now Vinçotte-certified.
Optional mountable USB soundbar
- The ability to access multimedia content on workplace devices is becoming increasingly important for businesses. In order to accommodate this need, the Samsung SE200 can be fitted with an optional USB soundbar. Thanks to a seamless mounting system, the soundbar attaches to the back of the monitor to provide the same benefit as a built-in speaker. This convenient add-on delivers quality sound (2.5 W) while saving space and keeping your workspace more organised.
A professional ergonomic monitor for truly professional needs
- VESA Support: With support for VESA 100 X 100, you can easily mount it on any wall.
- Tilt: Easily and smoothly tilt the screen forward 20° and backwards 21° for comfortable viewing.
Environmentally friendly
With recycled plastic, low power consumption, eco features to reduce power consumption when the monitor is in use and fully recyclable packaging, this is the perfect value monitor for the environmentally-conscious business. -
Impressive picture quality
The LED-backlit LCD screen delivers sharp, bright and beautiful images. Mega infinity dynamic contrast ratio helps to ensure subtle detail even in the lights and darks, and MagicAngle technology delivers quality color even when viewed off-angle. -
Slim design that fits any desk
The sleek, stylish design and low-profile stand take up less desk space and contribute to a cleaner-looking office. The built-in cable management feature also adds to a clutter-free work environment.
- Samsung S22E200B - SE200 Series - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/362915
- Energy Class
- Class G
- Power Consumption (On mode)
- 24 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.24825 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1976)
- Input Connectors
- DVI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Black
- 50.43 cm x 17 cm x 38.54 cm
- 3.37 kg
- Environmental Standards
- ENERGY STAR Qualified
- C-Tick, EN55022, SASO, EN55024, FCC Part 15 B, CCC, PSB, AS/NZS 3548, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, GB 4943-2011, GB 17625.1-2012
- 3-year warranty
- Display Type
- Energy Class
- Class G
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.24825 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72% (CIE 1976)
- Response Time
- 5 ms
- Vertical Refresh Rate
- 60 Hz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- MagicBright, power off timer, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving
- Black
- 50.43 cm x 17 cm x 38.54 cm - with stand
- 3.37 kg
- VGA , DVI
Mechanical
- Tilt
- Tilt Angle
- -2/+20
- VESA Mounting Interface
- 100 x 100 mm
- PVC free
- Cables Included
- 1 x VGA cable - 1.5 m
- Input Voltage
- AC 120/230 V
- 24 W
- Power Consumption SDR (On mode)
- 24 kWh/1000h
- Power Consumption (Typical)
- 21 Watt
- Power Consumption Stand by
- 0.1 Watt
- Power Consumption Sleep
- 0.1 Watt
- OS Required
- Windows 8.1
- Dimensions & Weight Details
- With stand - width: 50.43 cm - depth: 17 cm - height: 38.54 cm - weight: 3.37 kg , Without stand - width: 50.43 cm - depth: 7.75 cm - height: 30.19 cm - weight: 3.08 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
