Samsung S22D300HY 21.5" 1920x1080 5ms VGA LED Monitor
SEE IT YOUR WAY WITH WIDER VIEWING ANGLES!
Quicklinx: B4R4WS00 Mfr#: LS22D300HY/XU
Select:
  • 21.5"
Experience amazing levels of color, brilliance and picture quality through the very latest in Mega Dynamic Contrast Ratio. Samsung SD300 monitors deliver images so real-to-life that it will transform your whole viewing experience. Packed with breathtaking 5000000:1 contrast ratio, the highest level currently available, the SD300 monitor ensures that blacks are at their absolute darkest and colors are at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity. It is like an explosion of colors and leaves other screens seeming dull in comparison. So, take your viewing pleasure to the next level with Samsung Mega Dynamic Contrast Ratio - and enjoy your multimedia content with the professionalism it deserves.
  • Vivid visuals
    Experience true-to-life colors with the Samsung S22D300HY's 16.7 million color support and Full HD (1080p) video format. The LED backlight enhances image clarity, making every detail pop.
  • Seamless connectivity
    With both HDMI and VGA interfaces, this monitor offers versatile connectivity options, allowing you to easily connect to a wide range of devices.
  • Enhanced gaming
    Dive into your games with features designed to enhance your gaming experience, including a fast 5 ms response time and a special game mode that optimizes contrast and color settings.
  • Eco-friendly operation
    The Eco Saving feature allows you to adjust the brightness of your monitor to save power, while the power off timer helps further reduce energy consumption.
Samsung S22D300HY - SD300 Series - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
600:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
High glossy black
51.16 cm x 17.7 cm x 38.52 cm
2.9 kg
RoHS
Display Type
Energy Class
Class B
31 kWh
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
600:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
Power off timer, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale
High glossy black
51.16 cm x 17.7 cm x 38.52 cm - with stand
2.9 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-1/+20
1 x VGA cable
RoHS
Power Supply
External
Input Voltage
21 W
Power Consumption (Typical)
22 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 51.16 cm - depth: 17.7 cm - height: 38.52 cm - weight: 2.9 kg , Without stand - width: 51.16 cm - depth: 5.31 cm - height: 31.08 cm - weight: 2.65 kg
B4R4 StarTech.com Articulating Monitor Arm In Stock £118.99
B4R4 StarTech.com Dual Monitor Stand In Stock £80.12
B4R4 StarTech.com TV/Monitor Arm - Wallmount In Stock £82.22
B4R4 StarTech.com Monitor Arm - Heavy Duty In Stock £93.15
