Business monitors can be stylish as well as efficient. Your Samsung LED business monitor is designed with a very narrow bezel width, which delivers both better viewing and a more attractive look. It's compact, space-saving form will also help you to make the most of your working environment. You can also wall-mount it easily and achieve the best possible positioning. Thanks to Magic Angle technology, you'll enjoy a great visual experience from a wide range of viewpoints. The monitor even helps you reduce energy costs, as it consumes just 0.1 W while in standby mode.
Keep your work space as efficient as your monitor
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SC200 is the perfect choice. From physically moving the monitor with the carrying handle to quickly installing, the SC200 is ready to deliver an efficient and clean work space. Optimizing your office space is now easily achieved with the Samsung LED Business Monitor SC200. -
Maximize your space with easy wall mounting
Give your monitor the best possible positioning with the VESA Wall Mount. Easy to mount and install, it is convenient, safe, compatible, and the perfect partner to your monitor. You will always have a great viewing angle and it also makes the most of your space with its slim design. -
Upgrade to the next level with mega dynamic contrast
Mega dynamic contrast ratio delivers new levels of color and picture quality to your viewing experience with images that are real-to-life. A breathtaking Mega DCR contrast ratio shows blacks at their absolute darkest and pristine whites and other colors at their brightest. You will notice the crystal clear picture clarity. It is like explosions of colors that make other screens seem dull in comparison. Enjoy your multimedia content with the professionalism it deserves. -
Help business with cost-cutting technology
Minimize your work costs with the help of the DPMS 0.1 W feature. It ensures that your Samsung business monitor only consumes a maximum of 0.1 W while in standby mode. This amazingly low consumption is beneficial both financially and environmentally, and is simply unmatched by competitors. -
Samsung magic angle
With 5-mode angle management, enjoy a full visual experience with amazing picture clarity from whatever angle or position you view your Samsung monitor from.
- Samsung S22C200BW - LED monitor - 22"
- LED-backlit LCD monitor - 22"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- 1680 x 1050
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Matte black
- 50.24 cm x 18.5 cm x 41.35 cm
- 3.85 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Diagonal Size
- 22"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- 1680 x 1050
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Power off timer, MagicTune, MagicAngle, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving
- Matte black
- 50.24 cm x 18.5 cm x 41.35 cm - with stand
- 3.85 kg
- VGA , DVI-D
Mechanical
- Tilt
- Tilt Angle
- -1/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 24 Watt
- Power Consumption Stand by / Sleep
- 0.1 Watt
- Included Software
- Drivers & Utilities, Samsung MultiScreen
- Dimensions & Weight Details
- With stand - width: 50.24 cm - depth: 18.5 cm - height: 41.35 cm - weight: 3.85 kg , Without stand - width: 50.24 cm - depth: 7.74 cm - height: 32.98 cm - weight: 3.55 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 10 °C
- 40 °C
- 10 - 80%
